Old 08-30-2011, 12:16 PM   #1
Question
Laying Tiles Over Partially Removed Thinset
I had a contractor who did a very poor job of laying tiles.
He installed the hardiback board and started laying tiles using "tile laying cement" for lack of better word which I bought from Lowes. I realized they tiles were not level so after much discussion with him he told me to find someone else to do the job. Ok, made my job firing him easy.
I removed tiles with a pry bar as the cement was still wet. I also tried to scrape most of the cement from the hardyfloor. I will say much of it is still there.
I got a new contractor for advise. He is telling me to start over again. remove the hardiback, put a new one and do it all over again.
This is where I turn to you guys- Am I getting the right advise?
This is a new house build by NV Homes in 2006. It is a sun room, approximately 420 Sq. Ft.
LinusHarmon is offline   Reply With Quote
Old 08-30-2011, 05:31 PM   #2
Tileguy
Bud Cline's Avatar
A picture would be helpful but if the tiles where removed that quickly I see no reason to have to remove the Hardibacker...IF... the Hardibacker was properly installed in a fresh bed of thinset to begin with. Something tells me it was not so you tell me if it was or not. Then we can proceed.
Old 08-31-2011, 10:29 AM   #3
I agree, im betting the contractor didn't lay thinset under the backer board, which is supposed to be done. He probably just screwed them into the subfloor. Look to see if he did or not before you do anything. Also, check the backer board seams for level, this could be causing your uneven tiles.
Hardiw1 is offline   Reply With Quote
Tags
bad tile job, ceramic tile do-over, laying tiles over thinset
Is it necessary to get rid of paint on concrete before laying ceramic tiles? yummy mummy Flooring 41 03-17-2013 10:46 AM
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 10:31 PM
Laying Porcelain Tiles Over Gypcrete @ Lino Janet Flooring 11 07-30-2008 05:38 PM
Laying Tiles - Beginner peter1 Flooring 29 06-15-2007 11:15 AM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
