Laying Tiles On The Diagonal... - Flooring - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 08:01 PM   #1
Laying tiles on the diagonal...
OK, I've got a bathroom that I'm putting in 12" sq. tiles. The room is 74" x 60" - and the 12" tiles measure 17" on the diagonal. What is the proper way to diagonally place the tiles along the 60" side? Allowing for the base moldings I can start on the left side wall and lay three full tiles plus 1/2 tile on the diagonal to exactly fill out the 60". On the next row I would start on the right side with a full tile and the 1/2 diagonal tile would be ont he left side.
OR should I exactly center the diagonal tiles - that will give me three full tiles centered and two 1/4 tiles on each side. Would the eye follow the rows left to right and see that there is a full diagonal tile on one side and 1/2 tile on the opposite wall?
How would you pros lay this out?
Quickdraw is offline   Reply With Quote
Old 08-14-2010, 08:12 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't over-think this.
In simple terms...
I would draw two center lines bisecting the room each way. Then lay the tile corners (points) according to those lines. Fill to the walls from the center.
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
bryan1282 (08-08-2011), Quickdraw (08-14-2010)
Old 08-14-2010, 11:47 PM   #3
In simple terms...
Thank you. I didn't want to "overthink it" but laying three and 1/2 tiles wide seemed to be more desireable than using the two smaller 1/4 tiles to fill out the 60". Seems I'd read to always avoid using tiles smaller than 1/2 size.
Old 08-14-2010, 11:54 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That is always good advice but isn't always practical advice.
XXX
Old 08-08-2011, 09:08 PM   #5
Rewards Points: 77
old post, but i like the advice Bud Cline. laid out my bathroom floor tile dry using your simple method and almost every cut tile along the edge is the same size and it will look awesome. was going nuts trying to use only half tiles around the edge but it doesnt work out well that way.
bryan1282 is offline   Reply With Quote
The Following User Says Thank You to bryan1282 For This Useful Post:
Bud Cline (08-09-2011)
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 10:31 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
laying tiles damian Tiling, ceramics, marble 1 06-17-2010 06:55 PM
Laying Porcelain Tiles Over Gypcrete @ Lino Janet Flooring 11 07-30-2008 05:38 PM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
