Old 06-12-2007, 07:54 AM   #1
Laying Tiles - Beginner
I was wondering on a scale of 1 to 10 (10 being the most difficult), where does tiling stand? I'm thinking to tile about 25 sq feet near the entrance area and would like to DIY if possible.
one of the main concerns is cutting the tiles. Straight cuts are not much of an issue, I'm worried about those tricky cuts (L and U shapes), like around door jambs.
I've been told to use wet saws, others tell me just use an angle grinder, then there's also the tile nipper. So what's the best and perhaps easiest way to cut tiles into irregular shapes?
Thanks in advance for your input.
peter1 is offline   Reply With Quote
Old 06-12-2007, 10:36 AM   #2
Rent a wet saw and go for it. If you have any experience with a tape measure...and any kind of eye for straightness, tiling 25 sq. ft. should not be difficult at all. Getting a how to video would be wise. It will give you a feel for mixing the thinset the right consistency and grouting. Tiling a small area is pretty easy....assuming you are on a slab....wood floor requires some extra steps.
send_it_all is offline   Reply With Quote
Old 06-12-2007, 11:15 AM   #3
Thanks for your response. Is it possible to cut U shape using a wet saw? How do you cut the bottom of the U?
Also I've seen some relatively cheap wet saws, like under $100, are they cheap and nasty? Or acceptable for small jobs like this? I have no idea how much is the rental, I figure if it's going to cost $50 a day, then might as well just buy one (can be used in the future).
Old 06-12-2007, 01:03 PM   #4
I bought one of those cheep ones for my tiling it worked pretty well the only thing I would recommend is buying a good blade for it the ones that come with are very cheep and didnt last long ,after several cuts you start to get alot of rough looking cuts but a good blade will fix that or at least it did for me otherwise the only difficult part was it got a bit tough on the old back ( I have new respect for alot of the tradesmen who do home renovations and building )
clasact is offline   Reply With Quote
Old 06-12-2007, 01:23 PM   #5
I've cut a U shape before by cutting down the two sides, then using a chisel on the third side. One good whack and it broke right along a line between the two 'legs'.
billinak is offline   Reply With Quote
Old 06-12-2007, 01:47 PM   #6
I think cutting tile is kind of the not so difficult task comparing to other aspects in tile laying... I find the most challenge is really making sure the sub-floor is flat and level... once that is done... the rest is not really so hard....
KUIPORNG is offline   Reply With Quote
Old 06-12-2007, 01:51 PM   #7
I had no choice on mine it had to be a DIY the wife insisted. Im glad she did i learned a lot and it wasn't as difficult as I thought. I started with the kitchen 14' x 14' then the laundry room 8' x 14' and I just finished the bathroom 8' x 14'. For the U shaped cuts, i cut both sides of the u then I used the wet saw like a scroll saw. Remember to wear gloves when spreading the mortar. I didn't and it sucked every ounce of moisture out of my hands.Knee pads will help as well. Good luck and post some pics.
rick32 is offline   Reply With Quote
Old 06-12-2007, 03:01 PM   #8
If you got a Makita 9.6V cordless wet tile saw... you can cut any shape....
Old 06-12-2007, 04:53 PM   #9
If you come to a difficult cut, make a template out of a piece of cardboard the same size as the tile. Then trace the cuts onto a tile with a sharpie.
As long as the subfloor is sound, I give it a 2 or 3.
Jeekinz is offline   Reply With Quote
Old 06-12-2007, 08:28 PM   #10
weekend warrior
I have an cheapy wet saw, works fine for simple little jobs...
johnny331 is offline   Reply With Quote
Old 06-13-2007, 01:40 AM   #11
The U shaped cuts can be made by cutting the two sides of the U in the normal fashion, then the bottom of the U can be cut by using the blade-height adjustment to raise the blade all the way up so you can slip the tile under it without cutting, then plunging down into the tile in the middle of the bottom of the U. Or you can use an angle grinder with a diamond blade...or Home Depot sells a portable 4" wet saw that looks like a small circular saw with a garden hose attachment on it. It's pretty inexpensive and very handy for those odd cuts.
Old 06-13-2007, 07:22 AM   #12
Thanks for the feedbacks, it really sounds encouraging and I'm now a lot more comfortable going down the DIY path.
A couple more questions about cutting. If I get a wet saw, do I still need a tile cutter for straight cuts (the sliding kind with a long handle)? When cutting with a wet saw, the tile should be faced up or down?
Also how much gap should I leave in between tiles? Does it matter if I end up with skinny grout lines?
Sorry for all the silly questions.
Old 06-13-2007, 07:32 AM   #13
no you don't need the other cutter ,tile should be face down so you don't catch the ridges on the bottom , and the gap depends on you .Do you want big or small lines that is determined by what size spacers you get
Old 06-13-2007, 09:10 AM   #14
but cutting with wet saw is slower... for straight cut... but you are right you don't need it... unless you want to done it faster...
Old 06-13-2007, 10:19 AM   #15
I like to use a combination of both the wet saw and the snap cutter. I take the snap in the house and use it for straight cuts...it is much faster than walking in and out many times....but it wont cut some types of tile. The expensive type might, but mine wont. I have the $30 special.
More On This Topic
Hi, I’m faith and I’m here at Flat Fork Studio and I’m going to show you how to use the tile nippers to round off the edges of your tile. Basically, the concept is that you’re trying to take small amounts of tile in order to kind... Read More »
I'm now going to teach you how to use your tile nippers to break your tile. It's important to keep your safety goggles on while you nip your tiles because shards can still come up into your eyes, but you no longer need your gloves. To cut your tile, you... Read More »
Shaping Tiles for Mosaics
Shaping Tiles for Mosaics by Expert Village
Do you remember how our Mexican tile broke with really jagged edges? If you don't like these jagged edges, you can use your tile nippers to straighten them out. What you do is, you anchor the bottom of the tile nippers on the bottom, and then you anchor... Read More »
We're going to go into more detail on how to use tools later, but as a basic overview on what tools you'll need to make your tile mosaic project, you're going to need a tack hammer to break your tiles with. Also as I mentioned before, gloves and glasses... Read More »
Now in this segment I'm gonna tell you what kind of tools are needed. At least the kind that I use and I think most artists of mosaic use. You need a cutter, a glass cutter. And one that you can put oil on the top is preferable because it slides easily... Read More »
How long until tiles can have heavy traffic? leted_82 Flooring 2 07-31-2007 07:10 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
