Laying Tile Over Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 09:41 AM   #1
Laying Tile over Wood Floor
Hi,
I have gutted a kitchen and removed several generations of linoleum and am down to the original tongue and groove wood floor. Should I go ahead and install cement board first? If the answer to that question is yes, then would it be ok to use a subfloor grade of liquid nail instead of a thinset with the cement board?
Thanks.
Dick
RMCarner is offline   Reply With Quote
Old 04-30-2009, 09:57 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Dick,
Where did you get those ideas? All wrong!
If your "original" t&g floor is the subfloor, you can leave it, but you must install a plywood underlayment over it first and then the CBU or a membrane such as Ditra. If you go with the cement backer (CBU), it is installed into thinset mortar and immediately fastened and then taped per directions.
Jaz
Old 04-30-2009, 10:04 AM   #3
Originally Posted by JazMan View Post
Dick,
Okay. Why do I need a plywood underlayment? Not challenging you, just questioning.. Second, what are you recommending - 3/4" or what? And what type. This will really raise the elevation of the floor more than I anticipated adding the plywood.
Jaz
I bought Hardibacker board 1/4" from Lowes. I didn't know either about the membrane that is required.
Thanks.
Dick
Old 04-30-2009, 10:24 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
Dimensional lumber is too unstable to apply the Hardie or any CBU to directly. You should install min. 3/8" B/C underlayment grade or thicker, (I recommend 1/2" if the planks are in "like new" condition), the thicker the better of course.
Installing tile using this method will be lower than the old fashioned alternative. The old way you would install 1 1/4" or more of cement mortar, then the tiles. (Can be thinner if a small room like a bathroom) If you want all the floors to be the same level, install the same floor in all rooms.
You don't need both a CBU and membrane. One or the other. Ditra is a better method, is only 1/8" installed and of course costs 2.5-3 times more. but easier to work with and no silica dust that can kill you in 70 years. (?)
Jaz
Old 04-30-2009, 10:40 AM   #5
I'm listening. I'll opt for 1/2"
You don't need both a CBU and membrane. One or the other. Ditra is a better method, is only 1/8" installed and of course costs 2.5-3 times more. but easier to work with and no silica dust that can kill you in 70 years. (?) Jaz
I hear that. The cement board is nasty stuff. Okay quick run down. 1. Install plywood. 2. Get Ditra install with thinset. 3. Tile.
Any particular pattern laying the plywood? Thanks a bunch.
Dick
Old 04-30-2009, 12:51 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 388
OK,
1. Fasten the old boards, replace bad ones.
2. Install new ply with long edge across the joists. Fasten only into the subfloor. Use screws that are about 1 1/4" long, no cheap drywall screws. NO glue under plywood.
3. Install Ditra with modified thinset mortar using a 5/16" V trowel. Follow directions, make the thinset a bit thinner than normal.
4. Set tiles using a good grade of UNmodified thinset, even if the tiles are porcelain or other hard to bond tiles. Try to find Ditra Set thinset near you.
Jaz
Old 04-30-2009, 03:24 PM   #7
Quadfam4's Avatar
Saw a guy on DIY ten grand in your hand tell the guy he had to glue the CBU before he screwed it into the plywood is that right?
Quadfam4 is offline   Reply With Quote
Old 04-30-2009, 03:44 PM   #8
Thinset, not glue. The purpose of the thinset is to fill any voids. Any flex=bad.
bdobs is offline   Reply With Quote
Old 04-30-2009, 03:56 PM   #9
Quadfam4's Avatar
no it was glue. at first he just screwed down the CBU then the guy told him to take it up and use like liquid nails to glew it down and then screw it down. I am pretty darn sure it was glue not thinset came out of a caulking gun.
Old 04-30-2009, 04:14 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 388
ALL CBU's must be installed with either un modified or modified thinset (instructions tell you), under them. This thinset is NOT there to bond the CBU to the subfloor, but to fully support the sheets. The fasteners hold it down, the thinset hold it up, this way there is no movement.
Back in the '70's when "Wonderboard" first came out, it was suggested that the board be installed as you said. With a bead of construction adhesive around the perimeter, a big X corner-to corner and then "O"'s everywhere else. They learned within a few years the board was moving and many jobs had grout cracks. The current method has been the "law" ever since with great results if everything else is done right too.
There of course are still some people, even pros, that haven't gotten the news yet. And some of them will say they have never had any problems doing it the wrong way. I think they have, but just may not know it or the customers didn't complain. Hairline cracks are very difficult to see, and many people expect some small cracks in the grout, for some reason.
Jaz
Old 04-30-2009, 04:21 PM   #11
I installed Travertine flooring and tub enclosure in my bathroom. Just to see what kind of quotes I would get from the "pros", I had about 5 estimates given to me by licensed "pros" I found in the yellow pages.
I had used Hardibacker before, and did my research on a bathroom install.
3 of the 5 said they would simply nail the Hardi down directly on subfloor, 4 of the 5 said I didnt need a vapor barier over the studs for the tub enclosure, and not a single asked about my deflecto rating or joist structure. Upon me asking, one guy leaned on one leg and said the floor seemed stout.
Glad I did it myself
Old 04-30-2009, 08:08 PM   #12
OK,
Jaz
All good. Thanks very much. I have a hard copy of what you said and will follow your directions. Thanks
Dick
Old 05-19-2009, 07:54 PM   #13
ceramic tile over t&g flooring
my first question was on the black adhesive under the carpet i pulled up after water damage, how to get rid of it? I sanded it, but it will all not go away, i wanted to know if i could lay the tile on it and if it would be okay.
then i found out i have to put a plyboard or hardboard over the orig floor before the tile, doesn't that mean i need to remove all the baseboards and door trims, omg I think i'm getting myselft into something way bigger than i thought, the laying of the time is the easiest part.
i have all the tools, could wing the knowledge just need to know the steps in easy terms.
sandy
wahine is offline   Reply With Quote
Old 05-20-2009, 09:04 AM   #14
I relied on a 1500 watt heat gun to loosen the linoleum and tar paper from the tongue and groove floor. You don't need to apply much heat! In some places it all simply came off by force (big chisels, etc.) But, I did make sure to take it all off before laying down the plywood.
In my opinion, no. The only think I got rid of was the quarter round that was up against the baseboard.
Dick
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 07:46 PM
Best nail hole wood filler for hard wood floor Radjack Flooring 4 04-16-2009 08:17 PM
what sub floor for slate tile? gk02 Flooring 10 02-26-2009 09:49 AM
Laying 20 " Floor tile lwramsey Flooring 2 07-26-2008 06:09 PM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 04:19 PM
