Laying Tile Over Vinyl? Any Suggestions? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 09:48 AM   #1
Laying tile over vinyl? Any suggestions?
I'm getting ready to remodel my house the kitchen, breakfast nook, an laundry room has vinyl flooring. Was wondering if there where any suggestions or tips?
boog is offline   Reply With Quote
Old 06-10-2013, 10:41 AM   #2
Rewards Points: 13,274
My tip is to remove all of it and any 1/4" plywood or partical board below it.
Need to know what sized joist, the spans, and spacing of the joist also.
Old 06-10-2013, 10:44 AM   #3
Amateuralex's Avatar
Rewards Points: 270
I can't imagine anyone on this site not telling you to rip it out and put in a proper subsurface such as ditra or cement board.
Further, I'd be concerned about the deflection. That is how flexible the floor is. You've had vinyl on it so you don't know if it's strong enough to support tile. Tile is a LOT heavier and when it flexes it cracks. Can you see the joists underneath it, say from the basement or crawlspace? If I were you, I'd take this step very seriously. Tile installs are time consuming messes, and you really, really don't want it cracking a year later. Also please note that natural stone is a lot heavier than ceramic or porcelain tile and requires an even stronger floor.
Also, where are you located and how old is the vinyl? Some old vinyl had asbestos and you may want to eliminate that as an issue before you continue. If you provide your location and the age of the house, you'll get much better advice.
Amateuralex is offline   Reply With Quote
Old 06-10-2013, 10:48 AM   #4
It is on concrete slab. It's in south Arkansas an the house was built in 1975
Old 06-10-2013, 10:50 AM   #5
Handyman
If it were me... Definitely remove all of the vinyl tiles first with a floor scraper. Then add a layer of foam padding for a my subfloor layer. After I would put adhesion promoter on the sub flooring and bottom of the tiles before laying done the tile. I hope these helps. Good luck, let us know how things are progressing!
nicktools561 is offline   Reply With Quote
Old 06-10-2013, 10:56 AM   #6
Rewards Points: 270
Aha, that may save you a lot of potential pain.
If there's no asbestos involved, yeah a floor scraper and some legwork will remove the vinyl. Don't use a chemical to remove the remaining glue, it will lead it to soak into the concrete and you need a clean surface for the tile to adhere. There's a few machines you can rent, like a grinder, that will mechanically remove the glue and leave you with a great surface to tile to, or to use self-leveling compound on. Thinset and tiles go on very easily to healthy and clean concrete.
Old 06-10-2013, 03:52 PM   #7
Great! Thanks for the help!
Old 06-10-2013, 08:05 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
A 1975 tile could very easily have asbestos, so could the adhesive. Test first.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Amateuralex (06-11-2013)
Old 06-10-2013, 08:18 PM   #9
It's not tiles, it's in sheets. I don't know if that changes anything?
Old 06-10-2013, 10:17 PM   #10
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 151
I just remodeled my Kitchen as well, and I ripped out 4 layers of Floor first:
Deja-vue is online now   Reply With Quote
Old 06-10-2013, 10:18 PM   #11
Deja-vue's Avatar
Rewards Points: 151
Then:
Old 06-10-2013, 10:19 PM   #12
Deja-vue's Avatar
Rewards Points: 151
And new Layer to match Dining Room Area:
Old 06-10-2013, 10:20 PM   #13
Deja-vue's Avatar
Rewards Points: 151
Layer of Ditra:
Old 06-10-2013, 10:21 PM   #14
Deja-vue's Avatar
Rewards Points: 151
Tiles:
Old 06-10-2013, 10:26 PM   #15
Deja-vue's Avatar
Rewards Points: 151
Done:
110 year old slightly uneven wood floor - sheet vinyl or tile vinyl? JoesSweetheart Flooring 0 05-23-2013 10:53 AM
Mannington Adura Vinyl Tile digitaljimmy Flooring 2 02-03-2013 03:19 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Vinyl sheet tile install - remove or level ceramic? Craigkapo Tiling, ceramics, marble 3 01-21-2012 02:13 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
