Old 01-04-2013, 07:53 PM   #1
Laying tile over Saltillo tile
I want to lay tile over my Saltillo tile because of moisture problems. The slab is leaching the white eforance(sp). I was planing on using ditra underlayment. Is there any special thin set I need to use with the high leval of moisture? Thanks for any suggestions. Michael
Hornnumb2 is offline   Reply With Quote
Old 01-05-2013, 12:45 AM   #2
No form of flooring or paint will work if there's moisture coming up through the slab.
Is there a drain tile and a sump pump?
Working gutters.
Grade sloping away from the foundation.
No mulch or flower beds up againt the foundation.
Old 01-05-2013, 05:33 AM   #3
Super Moderator
Saltillo is a soft unfired clay tile---water will cause it to deteriorate---so , remove it before attempting to tile this area----
Laying tile over vinyl Walker88 Flooring 21 01-07-2013 09:05 AM
laying stamped concrete over old tile Kimmarie Flooring 24 03-20-2012 01:20 PM
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-27-2011 12:13 AM
laying 60cm x 60cm glazed ceramic tile macasusirex Building & Construction 8 08-19-2011 10:13 AM
How to figure out where to start in laying out tile cheryldtrixie Tiling, ceramics, marble 3 06-01-2009 12:49 PM
