-   -   Laying tile over Saltillo tile (http://www.diychatroom.com/f5/laying-tile-over-saltillo-tile-168263/)
Hornnumb2 01-04-2013 07:53 PM
I want to lay tile over my Saltillo tile because of moisture problems. The slab is leaching the white eforance(sp). I was planing on using ditra underlayment. Is there any special thin set I need to use with the high leval of moisture? Thanks for any suggestions. Michael
joecaption 01-05-2013 12:45 AM
No form of flooring or paint will work if there's moisture coming up through the slab.
Is there a drain tile and a sump pump?
Working gutters.
Grade sloping away from the foundation.
No mulch or flower beds up againt the foundation.
oh'mike 01-05-2013 05:33 AM
Saltillo is a soft unfired clay tile---water will cause it to deteriorate---so , remove it before attempting to tile this area----
