Laying Tile Directly Over Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 04:54 PM   #1
laying tile directly over linoleum
I was breaking up my kitchen floor and noticed that the previous owners layed ceramic tile directly over the original linloeum.
Is this a money saving technique? Is it safe when there are spills?
I tore it all down and placed hardiback before I layed new tiles. I'm just wondering if this way is safe to a degree, if I want to save money on buying/installing Hardiback boards before laying tiles in the future. Thanks!
survivor122 is offline   Reply With Quote
Old 07-23-2009, 11:25 AM   #2
Floorwizard's Avatar
it's a bad idea. plain and simple.
Cheap way to do a job, and not very bright.
Floorwizard is offline   Reply With Quote
Old 07-23-2009, 02:35 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
I'm no expert but I doubt the tile cement will adhere properly to it. Best to rip it out. Buy lot of pizza, beer, pepsi or w/e, its longer and more tedious then you'd think but it's the right way to go.
Old 07-23-2009, 04:07 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thinsets have been formulated that will easily adhere to vinyl sheet flooring - HELL, it says so right on some of the bags and none of those manufacturers would ever lie about such a thing.
That isn't the issue(s)!
Old 07-23-2009, 04:16 PM   #5
yea, just cause thinset will stick to it doesn't mean it can be used effectively.
Old 07-24-2009, 10:22 AM   #6
Nia
Do it the right way the 1st time and you won't have surprises later. They were just being cheap, lazy and trying to cut corners.
I was always told: do something the right way or don't do it at all!
Nia is offline   Reply With Quote
Old 07-25-2009, 03:23 AM   #7
i agree not a good idea. usually vinyl flooring is layed over a 1/4" cheep ply and once you get under it you can take it up pretty easy.
or screw hardibacker 3/8 or 1/2 over top then do the tile.
kreg McMahon is offline   Reply With Quote
Old 07-25-2009, 03:59 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Uhm-m-m-m-m-m-h! Are you sure that's OK?
Old 07-25-2009, 04:38 PM   #9
I would think Wonderboard or whatever is fine screwed down over existing Vinyl.
as long as the substrate is plywood.
Old 07-25-2009, 07:22 PM   #10
if you have the extra thickness room available... dishwasher etc. otherwise 1/4 " would do however, the thicker will make the floor stiffer... but also check joist span for extra weight. should be okay
bath room tiling question, laying tile around a curve everyman Kitchen & Bath Remodeling 2 02-14-2009 01:21 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-19-2007 11:11 PM
Tile over old linoleum? SeattleDuck Flooring 1 09-22-2006 02:58 PM
