Laying Solid Hardwood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 07:27 PM   #1
Laying solid hardwood flooring
Can solid hardwood flooring be laid without nailing or gluing down? i.e. make it into a floating floor
cynthiakaye is offline   Reply With Quote
Old 07-30-2012, 07:51 PM   #2
Rewards Points: 13,694
No, look into engineered flooring or laminate.
What are you laying it over that can not be nailed to?
Old 07-31-2012, 03:23 AM   #3
jerekwhitman's Avatar
Most engineered floors have a thin laminate top and wood bottom. if the flooring is less than 1/2 inch thick i would not advise nailing it and would float it instead, gluing the boards together at the tongue to prevent them separating or water spills permeating them. Read more.....
jerekwhitman is offline   Reply With Quote
Old 07-31-2012, 11:15 AM   #4
Rewards Points: 264
No it can not. The floor will fail. If you are asking because you want to go over a concrete subfloor, you can install solid over concrete but you first need to lay plywood over the concrete and then nail the flooring to the plywood. This should however be done by a professional as their are many issues that can arise from moisture in the concrete.
Awoodfloorguy is offline   Reply With Quote
Old 08-01-2012, 05:25 PM   #5
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
This is good advice as I have seen many failures.
Check into engineered flooring, there are many to choose from. Look at bamboo reconstituted engineered flooring. It has a higher "Janka rating" than oak and can be installed with a cushion. Some have a patented locking tongue and groove that locks the joint together to prevent spreading...........
I just can't remember it's name.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Hardwood flooring installation - Should these planks not be installed? htabbas Flooring 8 11-30-2011 07:50 PM
What type of moisture barrier is needed for solid hardwood naildown flooring? htabbas Flooring 10 11-30-2011 07:51 AM
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 10:44 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
