-   -   Laying solid hardwood flooring (http://www.diychatroom.com/f5/laying-solid-hardwood-flooring-152049/)
cynthiakaye 07-30-2012 07:27 PM
Can solid hardwood flooring be laid without nailing or gluing down? i.e. make it into a floating floor
joecaption 07-30-2012 07:51 PM
No, look into engineered flooring or laminate.
What are you laying it over that can not be nailed to?
jerekwhitman 07-31-2012 03:23 AM
Most engineered floors have a thin laminate top and wood bottom. if the flooring is less than 1/2 inch thick i would not advise nailing it and would float it instead, gluing the boards together at the tongue to prevent them separating or water spills permeating them. Read more.....
Awoodfloorguy 07-31-2012 11:15 AM
No it can not. The floor will fail. If you are asking because you want to go over a concrete subfloor, you can install solid over concrete but you first need to lay plywood over the concrete and then nail the flooring to the plywood. This should however be done by a professional as their are many issues that can arise from moisture in the concrete.
woody4249 08-01-2012 05:25 PM
This is good advice as I have seen many failures.
Check into engineered flooring, there are many to choose from. Look at bamboo reconstituted engineered flooring. It has a higher "Janka rating" than oak and can be installed with a cushion. Some have a patented locking tongue and groove that locks the joint together to prevent spreading...........
I just can't remember it's name.
Mike
