Laying Self Stick Floor Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 07:40 PM   #1
Tinker
I live in an older home and do not intend to stay long but would like to overlay self stick tiles over sheet vinyl. The self stick is slate patterned and 3/32" thick, dark slate finish. Will the lines from the under vinyl floor show through? Should I remove the vinyl and then lay the self stick.
Jo Jones is offline   Reply With Quote
Old 02-05-2013, 09:35 PM   #2
Rewards Points: 142
i put self stick over vinyl once. after a while the pattern from the sheet showed through. also, the tiles moved around a little, and some glue oozed out.
ymmv
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Jo Jones (02-06-2013)
Old 02-05-2013, 09:39 PM   #3
Rewards Points: 12,830
One of the last forms of flooring anyone here would have suggest to use.
Even a cheap laminite would be better then that.
Old 02-05-2013, 09:50 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Jo Jones View Post
I live in an older home and do not intend to stay long but...
Live with the vinyl sheet that's there until you go...
or replace what is there with new vinyl sheet and actually get the benefit of the work and expense rather than doing it in two or three years for the next owner benefit and so you can sell
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 02-06-2013, 05:41 AM   #5
Tinker
Self Stick Tiles
Thanks. It's kind of what I thought.Was just hoping the thickness of the tile and the color would camouflage.
Old 02-06-2013, 09:44 PM   #6
Rewards Points: 142
it just might, depends on how picky you are. i was happy with what i had. until i got the remodeling bug and became more picky. i then did a nice engineered wood.
and if i had removed the sheet, then did the tiles. the end result would not have been as good.
while joe is correct. peel & stick tiles do have their place. and are often better than the same priced alternatives.
Old 02-06-2013, 11:00 PM   #7
Tinker
Thanks for the self stick tile input
I know self stick tiles are not the best choice but in an old house that will probably be demolished, I'm just looking for a quick fix for about 3 years. If this were my permanent residence, I'd definitely get something professionally installed and go with a wood floor. I dislike laminate flooring because it's so noisy and cheap looking even with a cushion. Nothing like solid hard wood.
Thanks again everyone.
Laying floor over pre stick tiles phillysfinest4 Flooring 1 10-14-2012 09:27 AM
peel and stick vinyl wood planks - subfloor prep questions bonanz Flooring 11 12-07-2011 08:41 AM
Laying Ceramic floor tomorrow - Will mortar stick over glue residue? pure_energy1 Tiling, ceramics, marble 16 02-26-2011 10:41 AM
Laying self stick vinyl tile cocean Flooring 6 06-14-2009 09:21 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 08:52 AM
