Old 06-02-2008, 03:40 PM   #1
Laying Pergo Flooring
i WILL B LAYING PERGO FLOORING THIS WEEKEND. I HAVE DONE IT BEFORE BUTS ITS BEEN A WHILE. SO I HAVE SOME QUESTIONS. WHAT ATE THE BASIC TOOLS I WILL NEED?
ALSO IS IT TRUE FOR THE FIRST SHEET THAT YOU SHOULD RIP THE TOUNGE PART OFF SO THAT IS A FLAT SURFACE AGAINST THE WALL.
ANYONE HAVE TIPS FOR ME. IT IS GOING OVER TOP A PLYWOOD FLOOR. THANKS
JAVAMAN is offline   Reply With Quote
Old 06-02-2008, 03:55 PM   #2
Moderator
Termite's Avatar
The first sheet should be spaced about 3/8" from the wall to allow a little expansion room. Your base and base shoe will cover this, but you must be careful not to nail either into the flooring. Yes, you can rip the tongue off the first sheet.
Basic tools...
Jamb saw: to cut bottoms off door casing, if applicable.
Table saw: for ripping to width and cutting to length
Sponge: if you're gluing the pieces together
You are putting down a sound barrier aren't you? Rolled foam sheeting is common for floating floors.
Old 06-02-2008, 03:58 PM   #3
Tileguy
Bud Cline's Avatar
Pergo (like all flooring products) comes with instructions.
Saw, pencil, speed square.....
You sure you've done this before?
You NEVER install any flooring tight to any wall. A gap is always required and that information can be found in the instructions that come with the product.
ALWAYS read and follow the manufacturers installation recommendations.
Old 06-02-2008, 04:14 PM   #4
yeah i know there is supposed to be a gap between the walla s and the floor. is an 1/8 of a inch to small? I know the basic tools that i need, i just want to make sure i have it all cause i will be instaling it at a buddy's cabin in WEST. VA . and there are not many hardware stores around. thanks for the help
Old 06-02-2008, 04:25 PM   #5
Tileguy
Bud Cline's Avatar
.......is an 1/8 of a inch to small?
What do the instructions say about the wall gap? What does the manufacturer recommend?
Old 06-02-2008, 04:26 PM   #6
can or should pergo go in a bathroom? i have heard mixed opinoins on it.
Old 06-02-2008, 04:27 PM   #7
i don't have the product yet. i and just trying to remember the gap size that is typical. its going in a brand new addition.
Wanted: Pergo Paradigm laminate flooring PG 7005 Ivory Sandstone ridgebluff General Discussion 6 05-30-2008 04:03 PM
All about flooring – wooden floors (part 1) abraun Flooring 8 04-28-2008 11:46 AM
Pergo Presto - Snap, Crackle, Pop NickiB1109 Flooring 2 11-06-2007 11:34 PM
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 03:36 PM
