#1 |
Laying laminate flooring and need help
I'm laying laminate flooring and the end cuts that will butt up to existing carpet are slightly uneven. Is this a problem? how uneven can they be when using a molding strip how much does the threshold overhang to cover irregularities? if this is a problem what's the best way to fix it.
thanks in advance for your help.... |
#2 |
Fixer of all things Broke
jayrad131 You can set a skill saw to the right depth and tape a straight edge to the floor and trimm them that way. But I think if you arn't out more than a 1/4 inch the trim will cover it.
#3 |
It all depends on the transition strip that you use. If you use a T strip it should give you at least a quarter inch leway on either side. If you have more than that then see if you can find a bigger transition strip. The floor does not need to be as percise and when you install the final trim and moldings. Good trim work can hide alot of mistakes
#4 |
any idea where to find wider molding then?
#5 |
i'm also going to need a threshold that's 104" long. so far all i have seen is 94" any ideas where to get a longer one or how to make this work?
#6 |
I just laid some Cherry Pergo and didn't like the transition strips at HD because the only ones I saw stick up a 1/4" and look more like plastic than cherry. So I am going to make my own from Pergo and butt them at 90 degrees however this requires a very precise edge and maximim 48 " width / piece.
If you're not in too deep you should likely determine your edging now so you know how you will finish |
#7 | |
Laying laminate flooring and need helpQuote:
| Display Modes | |
