Laying Hardwood Floor In Large Room - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 08:36 PM   #1
Laying hardwood floor in large room
I have a 840 sg ft room I'm about to start laying hardwood flooring in. My question is should I start in the middle of the room to minimize any effects caused by even a minimal out of square corners? Thanks,great site
beech is offline   Reply With Quote
Old 08-18-2010, 09:36 AM   #2
Do work
Rewards Points: 81
If your first course is square then the last board will be square. I would start at the end.
liquidvw is offline   Reply With Quote
The Following User Says Thank You to liquidvw For This Useful Post:
beech (08-18-2010)
Old 08-18-2010, 08:57 PM   #3
Handyman
Rewards Points: 512
If you started in the middle, how would you nail the opposite boards?
canadaclub is offline   Reply With Quote
Old 08-19-2010, 12:55 PM   #4
But if the walls aren't square to each other then you are only square to the all you started at.
That being said you start at a wall. But which wall, that is the true question. You just mentioned a large room. Is it square or irregular? Are there many doors? Mating floor surfaces? Which way are you running the wood in relation to your walls and openings?
As a general rule, start against the longest solid wall that you have. This will probably be the most visible. Shorter wall runs are less likely to show variations in the squareness of the walls to each other in the overall room. If you don't have a single longest run of wall, start with the run that will be seen the most. Do not, generally, start at a floor transition. This is the best place to hide funny shaped wood planks.
unlvrebel is offline   Reply With Quote
The Following User Says Thank You to unlvrebel For This Useful Post:
beech (08-19-2010)
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 10:57 PM
Upstairs room gets hot... olcottke HVAC 6 08-13-2010 02:57 AM
Laying carpet for small exercise room J187 Flooring 10 09-30-2007 09:28 PM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 04:34 PM
Crazy large noise/vibration when turning on the shower in one of the bath room! Help! KUIPORNG Plumbing 6 05-25-2007 05:55 PM
