-   -   Laying hardwood floor in large room (http://www.diychatroom.com/f5/laying-hardwood-floor-large-room-79030/)
beech 08-17-2010 07:36 PM
I have a 840 sg ft room I'm about to start laying hardwood flooring in. My question is should I start in the middle of the room to minimize any effects caused by even a minimal out of square corners? Thanks,great site
liquidvw 08-18-2010 08:36 AM
If your first course is square then the last board will be square. I would start at the end.
canadaclub 08-18-2010 07:57 PM
If you started in the middle, how would you nail the opposite boards?
unlvrebel 08-19-2010 11:55 AM
But if the walls aren't square to each other then you are only square to the all you started at.
That being said you start at a wall. But which wall, that is the true question. You just mentioned a large room. Is it square or irregular? Are there many doors? Mating floor surfaces? Which way are you running the wood in relation to your walls and openings?
As a general rule, start against the longest solid wall that you have. This will probably be the most visible. Shorter wall runs are less likely to show variations in the squareness of the walls to each other in the overall room. If you don't have a single longest run of wall, start with the run that will be seen the most. Do not, generally, start at a floor transition. This is the best place to hide funny shaped wood planks.
