Old 01-03-2009, 11:56 PM   #1
Cool
laying hardwood floor?
i will be laying 3/4" x 3 1/4" hardwood floors in new construction. the subfloor is 3/4" t&g osb, screwed and glued to joists. how important is it to run floor boards at 90 degree angle to, and nailed at the floor joists? it is a good soild floor.
on hallways, does it look odd (big no no) to have the flooring run crossways instead of lengthways?
thanks.
gene_champ is offline   Reply With Quote
Old 01-04-2009, 09:05 AM   #2
Remodeling Contractor
Yes... nail to the studs. Where you cannot do this (hallway) use a nailing stapler instead. Generally you will run flooring perpendicular to the joist and maintain this direction everywhere. Do not run it lengthwise down the hall.
Old 01-06-2009, 01:09 PM   #3
thanks,
the installer said that it should be perpendicular to the main entrance for a more pleasing visual appeal.
i had never heard of that, but i don't have an eye for that detail. i am thinking perpendicular to joists should be a goal whenever possible beacuse on the more secure nailing. hallway would look much better lenght ways no matter the joists.
comments?
Old 01-06-2009, 02:07 PM   #4
hardwood flooring is always laid perpendicular to the studs.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 11:58 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
