Laying Hardiebacker Over Osb - Flooring - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 09:10 AM   #1
laying hardiebacker over osb
I am getting ready to put down 1/4" hardiebacker over osb subfloor....for use between these two materials, hardie recommends a dryset mortar with ansi spec of A118.1....for the tile on top of the hardiebacker, it looks like they recommend a latex or acrylic modified thinset complying with ansi spec A118.4 (Versabond Flex falls under this spec)....since I am a complete tile newbie, any suggestions....thanks
moegumble is offline   Reply With Quote
Old 08-06-2009, 12:05 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 412
That is not really what Hardie says. They tell you either non modified or modified is OK for under the board, but use modified to set the tiles to the board.
If it's a small job you may as well just buy one type, the modified. On large jobs you can use the cheaper unmod to set the board. I think Hardie is one of only a few that suggest unmod at all. Most other brands want you to use modified to set the board and the tiles.
Other tips? Heck there are hundreds of things. Like spacing the sheets and expansion joints to name a few.
Jaz
Old 08-06-2009, 05:05 AM   #3
thank, jazman
I understand what you're saying about the modified and unmodified....and, yes, I've already blown gaskets in my brain with all the little details....on the upside, i've cut the hardiebacker panels to fit exactly as specified, which was interesting due to angles, holes and cutouts..
laying down hardiebacker to osb moegumble General DIY Discussions 2 08-05-2009 12:56 PM
tips and tricks for laying and removing concrete forms? Allthunbs Building & Construction 8 06-10-2009 09:20 AM
Hardiebacker over tile? el_goodo Flooring 9 02-16-2009 08:06 AM
Hardiebacker 500 in shower enclosure question (does board facing matter?) DyerWolf General DIY Discussions 3 01-20-2009 06:58 PM
painting bathroom - primer for greenboard and hardiebacker? carrotguy Remodeling 5 06-23-2008 02:50 PM
