Laying Hardibacker - Flooring - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 06:14 PM   #1
Laying Hardibacker
A couple of questions for the experts. The instructions state it should be cemented to the sub floor and screwd down. I assume you put the screws in at the same time you set it in the cement. Also how soon before you can walk on it and start laying your tiles down?
blue collar is offline   Reply With Quote
Old 04-30-2012, 07:36 PM   #2
Rewards Points: 13,270
Not cement, use thin set, and use a 1/2 notched trowl.
And yes it get screwed down as it's set with special screws made for tile board.
You are using 1/4" tile board right?
Old 04-30-2012, 08:05 PM   #3
Correct. Thks
Old 04-30-2012, 11:00 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 290
Correction:
Do not use a 1/2" trowel like Joe suggested. He must have hit the wrong key.
Use a 1/4x1/4x1/4 trowel held at a low angle. Mix the thinset looser than normal, but not soupy of course. Even a little smaller trowel or a 1/4" that was worn a bit would be fine.
Screw the boards as you go and make sure you tape the joists with the proper fiberglass mesh backer board tape.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
DrHicks (04-30-2012)
Hardibacker Cement Board Thickness Issue With Drywall JasonCA Remodeling 4 02-24-2013 02:00 AM
Laying Hardibacker houstontilier Tiling, ceramics, marble 6 02-29-2012 08:25 PM
installing hardibacker board Tonglebeak Flooring 5 09-08-2011 10:28 PM
Hardibacker and groutable vinyl Wayne Perry Flooring 4 05-11-2011 08:19 PM
Can I use deck screws with Hardibacker? spaceman spif Kitchen & Bath Remodeling 10 10-26-2010 03:11 PM
