Old 10-14-2012, 09:15 AM   #1
Laying floor over pre stick tiles
I just ripped up the carpet on my second floor, it was old and smelled. Underneath there is plywood mostly but in some areas there is pre adhesive tiles. I ripped up one and it took a little plywood with it, and didn't come up cleanly. Can I lay carpet/laminate floors in top of them? Thank
phillysfinest4 is offline   Reply With Quote
Old 10-14-2012, 09:27 AM   #2
Laminate with the proper pad would go right over it or carpet will also work.
If you meant peel and stick tiles you can use a heat gun to get them out.
If the plan is laminite of carpet I'd leave them in place. Reason being your going to have a sticky mess once there out that would all have to be cleaned off
Peel and Stick Vinyl tiles nunie305 Flooring 3 03-06-2012 03:04 AM
Laying Tiles Over Partially Removed Thinset LinusHarmon Flooring 2 08-31-2011 10:29 AM
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 05:49 PM
Laying Tiles - Beginner peter1 Flooring 29 06-15-2007 11:15 AM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
