Laying Floor Over Existing - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 05:32 PM   #1
laying floor over existing
i have a floor with vinyl tile. i was wondering if there would be any problem putting a layer of felt over the current floor then adding 1/4 underlayment and vinyl tile on top.
the floor i pulled up did not have any underneath but there were slight crackling sounds on certain parts. could have been from the underlayment on the vinyl tile. i am trying to eliminate this if possible.
TDKEY is offline   Reply With Quote
Old 02-17-2013, 05:40 PM   #2
Rewards Points: 13,300
Is this layed over 1/4 underlaymant?
Two reason I can thing of for a noise is they skiped the parts where the underlayment needed to be attached every 4" on the outside edges and from 6 to 8" in the field, and Louan is not to be used.
Old 02-17-2013, 05:44 PM   #3
the vinyl tile is layed on top of 1/2 inch particle board. i am guessing that the noise if from some slight unevenness in the floor when walking on it. it is in the middle only in certain spots.
Old 02-17-2013, 05:52 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
You don't need the felt.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-17-2013, 05:54 PM   #5
#1 Linolium never should have been laid directly over partical board.
#2 Without a doubt Partical board is the worst subflooring ever made.
Gets wet once and it turns to oatmeal.
Will not hold nails or screws,
Just rising moisture from under the floor will cause it to swell up.
Want to fix this right, or just get by?
Tags
floor prep , underlayment
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
How to tap into an existing outlet to add a new one? jimhokie Electrical 10 01-17-2011 02:04 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 08:54 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 09:24 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
