how close does ditra need to be installed to a wall? i have a 42" wide hall, and i was wondering if it would be ok if centered the ditra in the hall or if i needed to cut it and put it down in sections so i completely covered the OSB
i was going to piece in the doorways. so are you saying i should cut it 42" wide and lay it across the hall instead of running it long ways? sounds like more time, but a better way for sure. also, what would be the minumum width that should be installed? i was thinking maybe 2", but not sure
jaz, worked great, thanks for your help. now all i need to do is find a good blade to cut porcelain. also, is kerabond a good thinset to use over ditra with porcelain?
Mapei's Kerabond is a very good premium unmodified thin set mortar. Mr. Schluter would approve if you used it. He would rather you use Ditraset, but if you can't find it, Kerabond is fine.
Jaz
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
