Laying Concrete Floor In Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 10:04 AM   #1
General Factotum
Laying concrete floor in bathroom
I am remodeling my bathroom and I need advice on how to lay a concrete tile floor over old 1950s porcelain tile. I am making the tile myself and am experimenting with different recipes for 3/8" x 8" square concrete tile using white and gray Portland cement, different coarse sands, pool mix, acrylic fortifier, hardware cloth and pigments. The existing bathroom tile is on the floor and half way up the walls; it is secure and passes the chain test and I want to cover all of it.
QUESTION: If sand down the existing tile and seal grout joints can I use some kind of mastic to "glue" my custom concrete tiles over it?
Ben Trevor is offline   Reply With Quote
Old 02-23-2010, 12:59 PM   #2
Newbie Bill
Rewards Points: 520
Are you saying you are NOT going to remove the existing tile?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-24-2010, 12:17 AM   #3
General Factotum
Right, I'm intending NOT to remove the existing tile. What do you think?
Old 02-24-2010, 06:01 AM   #4
DIY staff
Rewards Points: 7,174
In an ideal world you would peal off the old floor first---That being said---I must assume you find the existing floor stable and sound---I suggest you use a firmset mixed with a liquid latex.
Kerabond mixed with Keralastic by Mapei is a good example--I believe you could stick steel to glass with that stuff. -----------Mike----------
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 09:31 PM
Concrete Sealer for Bathroom Dayle Concrete, Stone & Masonry 9 02-07-2012 07:11 AM
Laying down laminate flooring on a concrete floor Joey_1984 Flooring 10 10-04-2009 08:42 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
