Old 01-04-2012, 04:46 PM   #1
Laying cement board on top of leveling concrete.
Just about to start a kitchen into laundry room tile project. The laundry room is an old addition with a slight angle away from the first room totaling 1/4 inch at the end of the room. My thinking is to use concrete leveling, then to put cement board down to join the two rooms prior to putting down 12x24 porcelain tiles. My questions are... Is it wise to level before securing the cement board down? Or use 1/8 inch cement board in the kitchen and use 1/4 in the laundry and level it that way? Is there an easier way? Thank you for the help.
dswenson is offline   Reply With Quote
Old 01-04-2012, 05:47 PM   #2
Super Moderator
Explain this more clearly---what is the floor now? If it is concrete--just level it---you can not put backer board on top---don't even try---not needed.
oh'mike is online now   Reply With Quote
Old 01-04-2012, 05:50 PM   #3
Tileguy
Bud Cline's Avatar
Wasting your time with those thought processes, think of another idea. You cannot install cement board over concrete if that's your thinking.
Besides...where would you find 1/8" cement board?
Old 01-04-2012, 08:26 PM   #4
Tileguy
JazMan's Avatar
I'm thinking the substrate is wood, not concrete. If so you need to install the backer board first then make the floor flat. Otherwise, flatten the floor then install a membrane such as Ditra instead.
Come back with details please.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Tags
floor, leveling, tile
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
Cement Board Questions trophywalleye Drywall & Plaster 17 06-29-2011 11:56 PM
Cement Board on Concrete Wall donrbenson Building & Construction 13 06-14-2011 10:04 AM
Cement Board -- Correct Install Method? unionmaid Kitchen & Bath Remodeling 9 01-09-2010 11:04 AM
Thickness of cement board on plywood ceiling hacksepe Building & Construction 5 09-13-2009 08:07 PM
