Laying Cement Board - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 01:21 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 412
You won't have any problems continuing the next day, just do everything the same way. How many sq. ft. is this anyway?
Jaz
Old 12-15-2009, 03:14 PM   #17
Rewards Points: 20
Jaz
Its about 220 sq. ft. I layed out the cement board to determine where I need to make cuts, so far its coming along.
oguevarra is offline   Reply With Quote
Old 12-15-2009, 05:35 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'll repeat: You should be sure to scrape any purging thinset from the edges of the boards. For sure don't leave it overnight then forget to do it the next day.
When thinset comes in contact with cement board the cement board rapidly wicks the moisture from the thinset and the thinset stiffens. If the purging thinset along the edges is allowed to remain, this is what causes lippage in adjacent cement boards. Keep up with it and it won't become an issue later. Even the short time it takes to go get the next board is sometimes long enough for the purge to stiffen and cause the edge of the next board to stand proud of the first.
XXX
Old 12-16-2009, 09:21 AM   #19
Rewards Points: 1,666
Is hardibacker needed under where marble threshold will be in doorway?
bob22 is offline   Reply With Quote
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
Thickness of cement board on plywood ceiling hacksepe Building & Construction 5 09-13-2009 07:07 PM
cement board install billyg Flooring 2 07-10-2009 12:52 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
