Laying Carpet For Small Exercise Room - Flooring - DIY Chatroom Home Improvement Forum
Old 06-19-2006, 01:06 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 502
Laying carpet for small exercise room
I wan't to lay some carpet down in my third bedroom to use as an exercise room. The room is 9 x 9 and has worn hardwood. I will be putting my exercise bike, a swiss ball and maybe some small dumbell weights in here. I'd like to protect the floor and give a smooth, level surface for the bike. I originally was going to do rolled rubber flooring, but the $$ turned me off. I saw some stuff on the roll at Home depot, I think it said Sizel or something. It seemed great for what I want and only $.52/sqft. My questions are:
Is it ok to just double stick tape the carpet down w/ carpet tape.
Do I need to put a pad of some kind underneath
when do you use pads underneath carpet anyway?
The carpet comes in 12x whatever ft lenghts and my goal is to not have to glue or nail anything to my hardwoods. Its really just a basic use of the carpet - thanks.
J187 is online now   Reply With Quote
Old 06-19-2006, 03:15 PM   #2
I do not think that you need the tape to hold down the carpet. Area rugs are put down on floors without tape. If you think that the edges may become a trip hazard then you could use the tape.
Padding is used to make carpet last longer and have a better feel under foot. If you do not want padding then it is not needed.
Padding makes a carpet feel more luxurious under foot. A higher end padding will make a carpet last longer if there is high foot traffic in the area.
You may also want to look at indoor/outdoor carpet. It is inexpensive.
redline is offline   Reply With Quote
Old 06-19-2006, 04:54 PM   #3
J187's Avatar
Rewards Points: 502
Thanks, thats all I need to know. great info
Old 06-19-2006, 10:55 PM   #4
Floorwizard's Avatar
dont forget that the backing of the carpet can scratch the wood badly.
if this is not a problem, then forget I said it
Floorwizard is offline   Reply With Quote
Old 06-20-2006, 08:44 AM   #5
J187's Avatar
Rewards Points: 502
Not really sure what you mean. Please explain...
Old 06-20-2006, 06:58 PM   #6
You could go to a carpet place and see if they have carpet remnants for your room. The price should be lower for a remnant.
Old 06-21-2006, 03:21 PM   #7
the backing of carpet is abrasive like sandpaper. if it comes in direct contact with the wood, it will leave abrasions.
Old 06-21-2006, 03:50 PM   #8
J187's Avatar
Rewards Points: 502
Oh, if its just small abrasions or whatever its not a problem, the floors would have to refinished in order to be nice anyway. Thank you - I appreciate the heads up!
Old 06-22-2006, 10:42 PM   #9
good point.
Old 09-30-2007, 08:40 PM   #10
If it were me I would refinish the hardwood and use exercise mats as needed.
flooring dude is offline   Reply With Quote
Old 09-30-2007, 09:28 PM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
OLD THREAD................resurrection
- Build Well -
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 09:25 PM
Tips on Laying Carpet? JustaFramer Flooring 10 12-02-2006 10:37 PM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-23-2006 12:01 AM
