Old 07-26-2008, 01:49 PM   #1
Laying 20 " Floor tile
Once I've made a cut for a partial tile to be placed along the wall can subsequent cuts be made to the same 20 " to continue down the wall--what I'm saying--can you lay tile with two cut edges--one with grout next to a full tile and the other next to the wall to be covered with base board?
lwramsey is offline   Reply With Quote
Old 07-26-2008, 03:40 PM   #2
Tileguy
Bud Cline's Avatar
Shouldn't.
Can't think of an instance where a cut in the field would be necessary on straight-layed tile. The cuts will normally show and look different than the factory edge.
Old 07-26-2008, 07:09 PM   #3
ccarlisle's Avatar
Put one down as you describe and see for yourself that the cut edge is sharper, presumably at a 90 degree angle - whereas the regular side of a tile is bevelled. You'd feel it when walking on it in bare feet.
Whats the reason for doing that? short a few tiles? trying to save $$? You might kick yourself later for not having done it well now. IMO, that is...
ccarlisle is online now   Reply With Quote
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-20-2007 12:11 AM
Laying Ceramic Tile leted_82 Flooring 2 07-18-2007 11:48 AM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
Romex laying across joist in attic? Doug Crf Electrical 4 08-17-2006 05:53 PM
