Old 03-06-2009, 12:59 PM   #1
Default lay travertine floor or install kitchen cabinets first?
I have searched forums but cannot find much, and I understand that there are pros and cons to both options, but would still welcome more input.
Do I install travertine flooring first or kitchen cabinets first?
I have removed old flooring and old kitchen cabinets.
Kitchen is totally bare except for short water pipes coming from floor.
I have a concrete floor (ok condition flat)
I will probably use a professional to install travertine, but do cabinets myself.
Time is not a concern, Kitchen and floor do not have to be rushed.
We can live without a kitchen for a few more days or weeks.
I would rather do what is best.
Thanks for any help.
palacenil is offline   Reply With Quote
Old 03-06-2009, 01:32 PM   #2
Super Moderator
Floorwizard's Avatar
More cabinets on the floor means less travertine needed to finish floor = less money and the job still looks great.
No brainer IMO
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 03-06-2009, 01:48 PM   #3
I'll vote the other way. I like the floor down first. Less of a chance for clearance problems with dishwasher and no need for a trim piece to cover the tile/cabinet joint. Just lay the travertine an inch under the cabinets and fill in the rest with a material of equal thickness.
jerryh3 is online now   Reply With Quote
Old 03-06-2009, 01:56 PM   #4
ccarlisle's Avatar
Floor first, as all height measurements for base cabinets and wall cabinets, dishwasher, fridge etc start from the floor height. You don't want to tile 'up to' a base cabinet, you want the cabinets to sit on the floor.
ccarlisle is offline   Reply With Quote
Old 03-06-2009, 02:21 PM   #5
and that is the problem...
I have been measuring and marking wall cabs and base cabs and have not been able to resolve every problem due to appliances and high pantry. Basically high pantry cabinet next to fridge which has a wall cab directly above it. Pantry has normal wall cabs and base cabs other side of it.
If I tile under fridge as normal, this raises fridge 3/4" which raises wall cab above it, which means it no longer lines up at top with pantry.
If I address this by also raising pantry 3/4" then bottom of pantry door no longer lines up with base cabs drawers. So icould raise the base cabs, then I end up raising everything so why not just tile the whole floor to begin with.
Yes, I understand some tiles will not be seen and so waste some money but i have to tile under range, fridge and dishwasher anyway.
Old 03-06-2009, 02:24 PM   #6
No brainer IMO
I understand that tiles under cabs are a waste of money. If I tile up to cabs, would you recommend still raising cabs to level of new tile floor, or leave cabs directly on top of concrete?
Old 03-06-2009, 03:20 PM   #7
floor first, you may want to re-design at a later date. you limit your ability to re-model your kitchen if you're working around where you layed the floor. Cheaper to do it now in the long run. You'll be able to chance it anyway you want and still have a great looking floor. If know 100% you'll NEVER want to re-model I guess saving a buck or two now might work.
Shifterson is offline   Reply With Quote
Old 03-06-2009, 04:05 PM   #8
ccarlisle's Avatar
So as I have it right - and correct me if I misread your post - but you have no floor, nor base cabinets BUT you do have existing wall cabinets?
That to me screams out "mismatching base and wall cabinets"...
But OK, lets say you want new base cabinets only. If you put the tiles 'up to' the new cabinets, it might look OK, but for the appliances you either tile right up to the wall (in which case you have your current problem) or you tile right up to the appliances (in which case you have a problem getting the appliance out for servicing).
Since we service our appliances more often that we remodel kitchens, it makes sense to tile right to the walls. And, if you want to keep the old wall cabinets, then you're going to have to live with the odd repair job, or misfitting parts here and there, goes with the territory.
But as far as tiling the floor goes, the savings of, what, $3 a sqft (?) under the cabinets is made up for the extra cutting it takes to make tiles fit. Best is to tile right up to the walls even around the pipes.
Old 03-06-2009, 04:11 PM   #9
Tileman-Manufacturers rep
Install the floor first when ever possible. No brainer.
Although it is possible to save some tiles? (Maybe not?) If you install the cabinets first, you will need to shim them more, plus the tilework will be more difficult to do and you increase the possibility of scuffing the cabinets too. I would charge more if the cabinets were in.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 03-06-2009, 04:42 PM   #10
sorry for any confusion.
no, right now there is nothing in my kitchen. bare walls and bare floors.
New kitchen has been delivered and sitting in my garage.
new appliances are also delivered and waiting to be installed.
I have been unpacking and measuring and "trying" wall cabs and base cabs.
By doing this I have identified potential problems, including height of wall cabs and base cabs with and without flooring.
In particular the problem with cab above fridge and pantry,
and potential mismatching height problem with sink cab and dishwasher cab if I tiled under DW but not under sink cab.
so brand new clean kitchen space, brand new floor, brand new cabs.
Old 03-06-2009, 04:47 PM   #11
Jaz
Thanks for the advice. I think I agree and I am beginning to think this is the safest way to proceed.
so that's 2 "no-brainers"
1 for cabs first, 1 for floor first.
That's why I love getting different opinions.
Thing is my concrete floor is in excellent condition and so chances are base cabs are likely to need more levelling shimming on top of tiles.
Old 03-06-2009, 04:56 PM   #12
Thanks for everybody's input. I do appreciate it.
Here's what I think it comes down to.
Laying base cabs directly on concrete floor will cause height problems with the base cabs that house appliances. Some cabs will be on 3/4" of top of tile, some will not be.
so options are;
OPTION 1 - install kitchen first, lay directly on concrete anyway and fix the height problems as they arise.
OPTION 2 - If I want to install kitchen first, install all base cabs that will not house appliances approx 3/4 off of floor so that these match the base cabs that will house appliances and be tiled. This way all base cabs will match height.
or
OPTION 3 - lay floor tiles first wall to wall and then install kitchen over the top of floor.
Old 03-06-2009, 05:35 PM   #13
Boy oh boy, when installing all new everything, measure where the cabs will go and mark out on the floor where they will end, tile just beyond that mark, tile all the way in the areas of the range, fridge and dishwasher, no need to waste all that tile under the cabs.
This way they still rest on the tile without having to cut around them, place scrap cuts along the back walls for the cabs to sit, if no scraps, just as easy to throw down some plywood strips the same height as the tiled floor, then shim and install the cabs as normal.
NO BRAINER.
R&D Tile is offline   Reply With Quote
Old 03-06-2009, 06:26 PM   #14
Yup I agree!
So the "No brainer" score is; The 2 tile guys say tile before when ever possible, and the vinyl & laminate guy says cut around the cabinets!
Oopps, sorry it's 4 to 1 I think?
Jaz
Old 03-06-2009, 09:15 PM   #15
In my humble opinion I would tile right to the wall, as stated you have the option of changing layout in future, also if you sell it is a good selling point. Also if you do have a leak from your dishwasher, sink or fridge ( if you have water to it), then it will not get under your tiles and potentially lift them. Tile the whole thing.
cheers
fixrite is offline   Reply With Quote
More On This Topic
For the most part, kitchens are meant to be functional. However, the space can also be fun and creative with the right touch. With the help of some decorating, it can become a place not only to cook--but also a place to congregate, socialize and relax... Read More »
Small kitchen appliances can actually take up a lot of space. Blenders, mixers, toasters, can openers, food processors, slow cookers, pressure cookers and other appliances can't all go on the counter top or your kitchen will look messy. They will also... Read More »
Whether you are remodeling an old kitchen or designing a new kitchen for a new home, functionality is the key to kitchen design. Having a functional layout in the kitchen not only makes the kitchen more inviting to your family and guests, but it also... Read More »
Hi I'm Betty Ingham and speaking on behalf of Expert Village and I would like to give you a little information on decorating a Victorian kitchen. One of the neat things about restoring an old Victorian house is you can do it the way you want to we wanted... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment I am going to be showing you how to do a dry run with your tile to make sure the layout is working. As you can see we have snapped our lines and what you can do if... Read More »
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 11 10-21-2009 07:15 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-30-2008 01:46 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 15 07-21-2008 01:32 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 05:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-19-2006 12:23 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
