Old 02-19-2009, 06:27 PM   #1
Flt_Simulation's Avatar
Lay plastic between ground and concrete slab?
Below is a photo taken of my new house under construction here in the Philippines.
Before they poured the concrete slab, they installed a layer of plastic sheet on top of the ground ... and of course you can see the rebar on top of the plastic that will reinforce the cement.
A friend of mine told be that installing the plastic will somehow keep the concrete floor from drying completely and will cause problems later on when tile is layed over the slab (some areas of the finished concrete floor will have engineered wood planking with the required pad)
I would think that the plastic is a good idea since it will keep the damp earth below it from effecting the concrete slab above and maybe keep ground moisture from entering the house later on.
What do you folks think .... Good or Bad idea?
Thank's
Ron
Bacolod City, Philippines
Flt_Simulation is offline   Reply With Quote
Old 02-19-2009, 06:35 PM   #2
the Musigician
DangerMouse's Avatar
i'd have to agree with you.... good idea.... heh
DM
Come join us in a card game@ www.igames2020.com for free!
For some ♠ Magical Fun, go to: http://www.youtube.com/user/MickeySoume
New card trick!--> The Vanishing American Card Trick <--CLICK HERE!
Old 02-19-2009, 07:43 PM   #3
Floorwizard's Avatar
I will not pretend to really know anything about this, but I would wonder how it will not be able to dry completely if the top side was exposed?
Now maybe if it was (sandwiched) by plastic.....
Floorwizard is offline   Reply With Quote
Old 02-19-2009, 07:57 PM   #4
Concrete does not cure by drying out but through a process call hydration. Installing a barrier such as polyethylene below the slab retards the transfer of moisture from the ground to the concrete. Your friend sounds like he has heard an urban legend or he's pulling your leg.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 02-19-2009, 08:20 PM   #5
the Musigician
DM
Old 02-19-2009, 09:59 PM   #6
Pro Flooring Installer
rusty baker's Avatar
In my area if you don't put plastic under the slab, it won't pass code.
Old 02-19-2009, 10:42 PM   #7
A plastic liner is good because it will stop some moisture from coming up through the slab... as long as it's the right kind of plastic.
The alkali in concrete will eat away at many plastics and disintegrate them over time.
Mudd is offline   Reply With Quote
Old 08-20-2011, 05:37 PM   #8
http://www.buildingscience.com/docum...20under%20slab
11. Concrete slab floors in ground contact are required to have a Class I vapor retarder below the slab in direct contact with the slab or rigid insulation having a thermal resistance of at least R-5 below the slab in direct contact with the slab.
jordao is offline   Reply With Quote
Old 04-22-2012, 06:56 AM   #9
Hi, I'm a new member who is building a house in Valencia (Dumaguete), Philippines.
I have not heard of inserting plastic between the ground and the concrete slab. However, you should definitely put some sort of barrier between any plastic piping, used in the plumbing for example, and the concrete slab or any other concrete. As Mudd said, if there is no barrier, eventually the concrete will eat away at the plastic piping and cause it to leak.
Philfun is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 35 Yesterday 09:53 PM
Concrete slab on sloped ground Cobb Building & Construction 1 12-01-2008 11:08 PM
Removing Concrete Ridge and Ground Protection on Ground Floor RayIII Building & Construction 1 10-09-2008 03:36 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
