Lawn Roller For Vinyl Glue Down Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 01:13 PM   #1
Lawn roller for Vinyl Glue Down Floor?
So i need to install about 2100 sf of ( Manington Adura) vinyl plank glue down flooring in my (soon to be arriving) new home. As I will be doing it in phases to meet the schedule of other buttom up work, I figure I'll need to have a roller on hand for 4-6 days. So , if I rent a 100# floor roller, it's going to cost me $150 or so. I cold buy it for just another $50 but then what do I do with it afterwards??
So I'm thinking that a $125 poly, water filled (160#) lawn roller might work well and actually have a use when I'm done witht he floors. Thoughts?
weehooker is offline   Reply With Quote
Old 02-15-2013, 01:12 PM   #2
Did You Use It?
Did you buy the lawn roller and use it? If so how did it work? I'm about to do a floor and having the same consideration.
jibjababudab is offline   Reply With Quote
Old 02-15-2013, 11:15 PM   #3
Sorry, no. I ended up finding a 100# floor roller on my local Craigs list for $100. Now I need to bu a lawn roller as I land scape this year!
Old 02-16-2013, 02:38 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 290
Buy mine, buy mine!
Lawn roller for the floor is not a good plan. However, a rolling pin..........., if you can stand being on your kneels that much. But if you're installing floors you're already there.
Jaz
Old 02-16-2013, 06:17 PM   #5
I did buy a hand roller from Home Depot for $30 or so to do the edges and hard to reach places. It worked "OK" but took allot of effort because you had to really lean on it. It was better than nothing but I don't think it put the same pressure on as the 100# unit. That said, in the end, it all stayed put.
Old 02-17-2013, 12:25 AM   #6
Solution
Thanks for the info and suggestions. I did a floor last year with a rolling pin and had severe tendinitis pain for six months.
Here's my solution: I'm going to take a 20" piece of 6" diameter PVC, insert a piece of 1/2" PVC down the middle and fill it with cement. I can then take a piece of thread stock, use it as an axle inside the 1/2" pvc center bore and attach a handle (wood or pvc) to move it back and forth. I figure it'll cost me about $25 - a poor mans floor roller.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
glue for allure floor? miltey Introductions 1 11-06-2010 10:05 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Black tar-like glue on basement floor diyinohio General DIY Discussions 7 12-21-2008 01:23 PM
