Laun Install Help For Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 08:24 PM   #1
Laun install help for vinyl flooring
I am ready to install some lauan on my subfloor but I have some questions. This is an old farm house that I have just finished replacing the subfloor on and the bottom side will be sprayed with the closed cell foam insulation. Do I need to lay down a vapor barrier on the subfloor before I install the lauan? If I do what do I use felt paper, plastic house wrap or another type of material. I am not sure if it would need a vapor barrier since the bottom side of the floor will be sprayed with the foam insulation.
RobertN is offline   Reply With Quote
Old 02-12-2010, 07:01 AM   #2
Closed cell foam is a vapor barrier.
You never want two vapor barriers because moisture can get trapped between them.
Dairylander is offline   Reply With Quote
Old 02-12-2010, 09:01 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
The vinyl floor itself will be enough of a vapor barrier.
Old 02-12-2010, 09:14 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
Lauan is not the recommended choice for vinyl underlayment, if that is what you are installing, but I used it for years and never had a problem. It can have voids in the layers that can cause problems.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
Crazy?....but how do I install hardwood flooring on wall yummy mummy Flooring 37 01-08-2009 06:19 PM
Nailer for flooring mpt1123 Tools 2 07-08-2008 01:24 PM
Peninsula install on Laminate flooring? mcaanda Building & Construction 1 05-22-2008 01:01 AM
