Old 06-18-2009, 05:40 PM   #1
Laticrete 1776 grout enhancer problem
HELP!!!!!!
I used too much water to clean the grout of my floor tiles during the
grouting process(the mix had no water in it just 1776 enhancer and laticrete sanded grout)
The grout dried almost white
The color should be dark beige
Right now i'm doing the final clean up 24hrs later using a damp sponge and some cheese cloth.The dark tan color returns when damp but as soon as it dries it whitens up
I'm going call the manufacture tomorrow
money-pit is offline   Reply With Quote
Old 06-18-2009, 05:41 PM   #2
2nd Gen. Tile Setter
Order a bottle of colorsealer in the color of your grout and apply. Will give an excellent seal and take care of your problem at the same time.
DeWoof01 is offline   Reply With Quote
Old 06-18-2009, 06:11 PM   #3
Any particular manufacture?
Old 06-18-2009, 06:25 PM   #4
I go with grout perfect or inject-a-floor systems.
Old 06-18-2009, 07:03 PM   #5
any idea what I did wrong?
How do do you clean up the excess grout with a dry sponge?
I'm thinking if I didn't use the 1776 enhancer and just used plain water in the grout mix I wouldn't have had this problem
DIY can be very costly with the wrong advice(lowe's salesperson)
Old 06-19-2009, 06:56 AM   #6
Doer of Many Things
poppameth's Avatar
I haven't used the grout enhancer before, but it shouldn't cause you such problems. Normally your problem is caused by over watering during cleaning. You use a damp sponge, not wet. There are a few products that can help you. Aquamix makes and epoxy grout colorant and sealer that will definitely solve the problem. They also make a cheaper product called Enrich and Seal that will return the color to it just like it does when you wet it now.
poppameth is offline   Reply With Quote
Old 06-19-2009, 03:22 PM   #7
I called the laticrete today and they are sending me some sealer and color thanx for the help
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
Difficulty removing grout ????????? nsb318 Flooring 12 02-19-2007 11:47 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
grout problem farrington135 Building & Construction 3 10-17-2005 06:30 PM
