Larry Long - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 02:53 PM   #1
larry long
I am new at flooring so I need help getting started with the layout.
My son's kitchen is an L shape and I will be installing vinyl planks, 1'x4'.
where do I start?
Thanks for any help.
Larry
lwlong@yahoo.com is offline   Reply With Quote
Old 12-08-2008, 03:26 PM   #2
bradnailer's Avatar
If there's a main entrance to the kitchen, you'd normally run them perpendicular to that entrance, meaning as you look into the kitchen from that entrance, you'd be looking down the planks. You would normally try to center them in the most visible area as well, where you'd have an equal plank on each side.
That said, before you do anything, just lay them out dry and see what your son's wife likes the best.
bradnailer is offline   Reply With Quote
Old 12-08-2008, 07:43 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
Without precise measurements it is impossible to answer, except for "bradnailer's" attempt to suggest the direction of the grain, which he misspoke and got backwards. (said perpendicular must have meant parallel?)
The pieces are 12"x48", should be easy to plan? I suppose the lengths will be staggered? Give us dimensions.
Jaz
Old 12-09-2008, 08:03 AM   #4
Thanks for the response, as soon as my son gets back from his trip I'll measure.
Thanks again
Larry
How Long Do We Have? Docfletcher Off Topic 19 05-01-2010 11:02 AM
How long a run to septic tank? GregWCIL Plumbing 8 06-28-2008 03:04 PM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 12:37 PM
