Large, Soft Areas In Newly Laid Tongue & Groove Floating Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 02:19 AM   #1
large, soft areas in newly laid tongue & groove floating floor
I just had an entire house done with engineered t & g. First we cleaned the concrete, and then laid down the foam underlayment that came with the floor. The wood was laid and glued together. Now that several rooms are done, there are several 'soft' areas where, obviously, there were low, uneven areas in the concrete. Bummer.
So, obviously, I should have leveled first, but didn't. What can be done now, after the fact? Will the floors drop some and settle in? Will putting heavy stuff on top of the floors for some time help them to settle? Can they be somehow ‘nailed’ down in just a few places? Or is it hopeless? Obvioulsy, I could take the floor out and re-level…..
Any input would be appreciated. Thanks- David
dfeigin is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Wood floor on a tongue & groove subfloor. Huckleberry Flooring 4 05-10-2011 09:41 PM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 06:27 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
