Large Porcelain Tiles For Shower Walls - Flooring - Page 5 - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 04:51 PM   #61
Tileguy
JazMan's Avatar
Rewards Points: 288
The shower valve will probably work backwards, but there may be a problem with proper gpm flow. Ask your question at the plumbing forum at this site. Click above near the header.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
BigJim (01-24-2013)
Old 01-24-2013, 05:04 PM   #62
DIY staff
Rewards Points: 7,174
Depends on the brand and model--but my guess is --no--the newer mixer valves are not simple water shufflers---they have a pressure balancing cartridge--so nobody gets scalded if the hot or cold water pressure changes suddenly----
you may need to go to a plumbing house for a proper valve.
JazMan (01-24-2013)
Old 01-24-2013, 06:26 PM   #63
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
I didn't think about that, well back to the drawing board. After thinking about the valves I will need three shut offs instead of two anyway. I am trying to stay away from the manifolds because they are out of our reach. I have found fairly nice looking shut off valves on line but they are the really cheap ones and I don't think they will hold up long. There has to be a way to have all three fixtures working without breaking the bank.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-24-2013, 10:09 PM   #64
DIY staff
Exactly what are the three fixtures?
Could two separate mixer valves be used and one switching valve?
Old 01-30-2013, 02:30 PM   #65
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
I don't know how I missed this post. Mike there is a 1.5 gpm shower head with a Delta one leaver scald guard valve on one end and there will be a 2 gpm shower head in the center over head sort a like a rain shower. On the other wall at the seat will be a hand held sprayer and shower head combo. I have it figured out now, I think. The old valve I took out I reworked as it is a Delta and in great shape. I reinstalled it below the new scald guard valve and hooked the feed into the same shower head as the new Delta.
The old valve had a shut off for the shower or the tub. It isn't the type where you have to pull a nob up on the tub spout, this one you just turn the center valve. I am going to use the center valve to go to the over head shower head and the hand held at the other end. I will need a two way valve to divert the water from the over head shower to the hand held. Here is the set up I posted in another thread. The supply line for the over head and hand held is stubbed out pointing downward in the lower valve.
I plan to install T&G western cedar overhead after I drop the ceiling over the shower. I do not plan to use any trim on the ceiling, I can cut it close enough where none is needed. My question is, should the cedar ceiling butt the tile, or should the tile butt the ceiling.
Here is the way I have it plumbed now.
Large Porcelain Tiles for Shower Walls-plumbing-6.jpg   Large Porcelain Tiles for Shower Walls-plumbing-5.jpg
Jim
Old 01-30-2013, 02:38 PM   #66
DIY staff
You are a better woodworker that you are a tile setter----I vote tile first--then wood--
You might even want to 'bread board' the cut ends--that would not add much to the work and give the bead board a nice finished end----
Old 01-30-2013, 02:45 PM   #67
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
You are right, I have done way more wood working than tile. I don't follow you on the bread board cuts on the ends, you know how I am, kinda thick.
Jim
Old 01-30-2013, 04:48 PM   #68
DIY staff
Instead of the cut end butting against the tile-----add a strip of the cedar to that edge first--then bitt the cuts against that----a groove in the 'bread board' and a tongue on the strips would really keep the ceiling looking trim---
Think of the way you would end a hardwood floor around a hearth----or at a doorway.
Old 01-30-2013, 06:04 PM   #69
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
Now I see why you make the big bucks, that will look sharp buddy, thanks a ton.
Jim
Old 01-30-2013, 06:08 PM   #70
DIY staff
Little details add a lot----
BigJim (01-30-2013)
Old 02-11-2013, 06:24 PM   #71
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
I am at the point of installing the durock. Today I built the inset and discovered there are very few studs that are plumb, what a mess. Here is the deal the shower base is close enough to level to call it that, maybe just a fudge out but not enough to worry about but, with the back wall is almost an inch out of plumb and the base maybe 3/16" out of level, I don't know exactly which way to go.
I cut a straight 2X4 and took a tile and set the tile down on the base and the back edge of the tile against the 2X4 to see how out of hoo doo it is. If I rip a 2X to fur the back wall to fit the tiles it is going to look somewhat out of plumb, I think. The first run of tiles will have to be cut to work out the way I want them to layout anyway. If I rip a strip to make the back wall in plumb and cut the first run of tiles on the side walls to keep the same margin at the bottom I think that would be the least conspicuous. Does this sound about right.
Remember I am an ole nail whooper, they use to call us, "Pouncy pound and the nail driving five"
Jim
Old 02-11-2013, 07:39 PM   #72
DIY staff
No tub or shower base is perfect---so count on a cut on the first row----
Any way to sister in some studs to plum up the walls?
Old 02-11-2013, 08:24 PM   #73
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
I just about have it furred out now. Another question, on the durock I have 3 feet on the side walls, can I just stand the durock up the five foot way or do I have to stack it the 3 foot way?
On the thinset, do I put the fiberglass tape on the seams then put the thin set into the tape or do I make the thinset really smooth in the joints, let dry the put the fiberglass tape over the thinset joints?
Jim
Old 02-11-2013, 08:36 PM   #74
DIY staff
Stand up the narrow side of the shower----taping---first press some thinset into the gaps--then top with the mesh and add the thinnest possible layer of mud----the mesh will show---that is okay--
the Red Guard is thick and will bridge small gaps-
You do not want a hump---thin---very thin is best---
Old 02-11-2013, 08:54 PM   #75
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
Thanks buddy, you are a life saver. I wish I had stuck around and watched the tile guys now. I have done tile where I had to put in a thick mud bed, soak the tile in water over night and use dry portland sprinkled on the mud bed as an adhesive but this new day materials I haven't used but a few times.
Jim
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
porcelain tiles humberguy Flooring 0 01-14-2010 05:06 PM
Stains on polished porcelain tiles tommurphy73 General DIY Discussions 4 12-24-2007 01:03 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
Porcelain Garage Tiles? head_dunce Flooring 6 02-22-2007 04:28 PM
