Lap Marks In Refinished Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 01:56 PM   #1
Lap marks in refinished floor
I recently had my wood floors sanded and refinished using the Bona water based products.
There are a few visible lap marks in the polyurethane after the last coat went on.
Is there any way to get rid of these marks without rescreening the entire floor?
Will these lap marks fade a little over time?
Thanks for the help.
DDASH is offline   Reply With Quote
Old 08-03-2011, 02:10 PM   #2
waterbased clear coats are bad about that. Is it a sheen difference you're seeing or just the visable height of the lap from the rest of the floor? Sheen will "die down" some but if it's a noticeable difference in thickness, sanding it down is the only option.
Duration is offline   Reply With Quote
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-02-2011 11:10 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 06:49 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
