Laminating 2 Rooms + Hallway Without Transitions - Flooring - DIY Chatroom Home Improvement Forum
Old 08-01-2008, 02:30 PM   #1
Arkanoid's Avatar
Laminating 2 rooms + hallway without transitions
Is it possible to laminate my entire 2nd floor in one big piece? It consists of 2 medium sized rooms connected by a 12' hallway. I'm trying to plan it out but it seems really tricky!
Otherwise, I'll do each room separately and use a transition between the doorway and hallway. I'd rather not do that. Any ideas?
Arkanoid is offline   Reply With Quote
Old 08-01-2008, 06:21 PM   #2
Guest
Guest
Posts: n/a
It's possible but I wouldn't recommend it. Most laminate companies want a transition very 30' max. If you are going through doorway especially you are getting into a tricky situation. Laminate floors are designed to float. They move with changes in environmental variables. It's a lot easier for them to do this effectively on a room by room basis. Trying to do it all in one big shot forces the floor to move all at once with stress at the smaller junctions.
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Recess in Hallway redman08 Electrical 1 07-21-2008 06:15 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Engineered Flooring Doorway Transitions? GaryD Flooring 1 12-21-2007 06:06 PM
narrow hallway txbostont Building & Construction 1 11-01-2007 05:17 PM
