Laminated Floor - Subfloor Preparing - Flooring - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 06:30 AM   #1
I am installing floating Laminated Floor. The instruction says it can be installed on any surface as long as the surface is flat. Since my room currently already have have the carpet. Can I just overlay the floating Laminated floor over that?
Looking for any advice. Thanks in advanced....
playdoh888 is offline   Reply With Quote
Old 09-21-2008, 01:30 PM   #2
about the only type of carpet you could possibly go over is a commercial grade
that is glued directly to the floor. Put some of the laminate together on top of
the carpet to see if there is any movement when stepped on, if there is NO
therugdummy is offline   Reply With Quote
Old 09-21-2008, 02:10 PM   #3
Registered User
Termite's Avatar
Putting a laminate floor over any sort of carpet would be an incredibly poor idea. Although technically a floating floor, it needs a solid substrate. Carpet ain't it.
Old 09-23-2008, 03:27 PM   #4
Drywall contractor
Rewards Points: 1,070
Worked on a job a few yrs. ago where a bank was converted to a restaurant. Glue down commercial grade carpet (as "rugdummy" described) was in place. It WAS NOT coming up without a lot of effort and expense that the new owners could not afford. Laminate was professionally installed, BUT warranty was voided because it went in over the old carpet. (Owners were willing to take the risk...) Restaurant lasted less than a year and I don't think there were any problems, BUT if you have carpet and pad (as in a typical residential situation) I think you're asking for trouble. Take a piece of typical laminate flooring and see how easy it is to break the tongue off. Walking on the laminate with the "give" of carpet and pad underneath and your floor will be breaking apart in no time. This is not my area of expertise by any means, but I have installed a few of thousand feet in my own home, in-laws homes, and a for few customers. I would pull the carpet.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-24-2008, 04:44 PM   #5
Thanks...
Thanks for all the advices... I will get rid of carpets before put on the laminated floor.
Old 09-25-2008, 05:40 PM   #6
Floorwizard's Avatar
good advice all around.
Floorwizard is offline   Reply With Quote
Old 04-26-2012, 10:43 AM   #7
installing laminated flooring around fireplace
karen0355 is offline   Reply With Quote
Old 04-26-2012, 11:09 AM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
And???????????
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-26-2012, 11:17 AM   #9
Rewards Points: 14,312
Karen please go back and add your own post, do not just add onto someone elses.
Plate glass windows in 2nd floor loft? kcrossley2 Building & Construction 9 04-01-2007 07:29 PM
