laminate wood flooring over concrete
Hello all,
We are wanting to replace our carpet with laminate wood flooring but are kinda confused.
I've visited a lot of websites trying to find how to do this and Im stuck between two options.
Website 1 said: Make sure the concrete is clean and completely level. Lay a layer of 6mm poly over the concrete to eliminate moisture. Then start laying out the laminate.
Website 2 said: Make sure the concrete is clean and completely level. Place plywood on top of the concrete. Then place padding on it. Then lay the laminate.
Could someone please tell me which advice to use.
Also, what can I use to clean the concrete?
Thank you so much in advance.
