Old 04-03-2011, 04:18 PM   #1
Laminate wood flooring around stair railing
Hello,
My husband and I are in the middle of installing laminate wood flooring in our living room and on our staircases. We are almost finished the living room but can't figure out how to finish the job around the stair railing where it attaches to the floor. We can't go over it (the way the carpet used to) as it creates too much of a bump, but we also can't simply go around it because then the ugly screws on the railing would be exposed! How do we solve this problem?? Please see the attached picture for a better idea of what we are dealing with! Thanks!!
Murphys is offline   Reply With Quote
Old 04-05-2011, 12:44 AM   #2
Master of none
I would install the laminate around the railing base, then mill a 2 piece hardwood cap and install it on top. The cap would be stained to match the laminate. You may be able to use the same material that you use for the stail nosing. The reason for the 2 piece cap is to fit around the upright.
By the way, the base of the stair railing looks rather rough. Is it all the same? Do you plan to pretty it up?
handy andy is offline   Reply With Quote
The Following User Says Thank You to handy andy For This Useful Post:
Murphys (04-05-2011)
Old 04-05-2011, 10:24 AM   #3
Thanks for the advice! (And yes, it did look pretty rough, but we had just finished pulling up all the carpeting and tearing up all the tacks that were holding it down. And the railing itself will soon be painted back to its original white. It already looks much better!
Old 04-05-2011, 10:41 AM   #4
old guy contractor
tcleve4911's Avatar
It looks like you can unbolt the railing, slip the laminate underneath, pre-drill the laminate and then bolt the railing back down.
This would look a lot better than scabs of wood trying to cover a detail.
tcleve4911 is offline   Reply With Quote
Old 04-05-2011, 10:54 AM   #5
We thought of that too... but since this railing doesn't end here (it makes a turn and goes up our MANY flights up stairs), we can't lift it up and put the laminate under it. We wish!
Old 04-05-2011, 09:01 PM   #6
old guy contractor
tcleve4911's Avatar
Sorry....can't is not in my vocabulary.
Why not?
Have you tried?
Old 04-05-2011, 09:53 PM   #7
We don't want to try lifting the railing because doing so would require us to lift it in all the places it is attached going all the way up our 5 staircases or else it would sit crooked if we just lifted the one area. That is a much bigger project than we are wanting to take on just now since it would mean moving the entire railing, painting the walls anywhere that it used to be attached, etc... It's just not something we WANT to do.
The only thing we are looking for is a solution for covering the bottom of railing. We do not want to replace or move the railing.
Old 04-05-2011, 10:43 PM   #8
old guy contractor
tcleve4911's Avatar
I will ask again...did you try it?
Your laminate floor is probably 3/8" ?
Undo those screws in the floor and pry up on the railing.
I bet you can slip that piece under it without disturbing any other part of the railing.
Worth a try...if not .....oh well
Old 04-08-2011, 04:59 PM   #9
The laminate is a floating floor with a HDF core=not sturdy. With a floating floor pad underneath it would be prone to cracking when you torqued down the screws (and they do need to be torqued down to make the bannister stable.
The cap well executed will look very nice, I'm not sure if I would have come up with an idea that good off the cuff.
Jamy Spencer
www.stlwoodfloors.com
Jamy Spencer is offline   Reply With Quote
Wood Laminate in the Kitchen quesenbarrett Flooring 4 03-21-2011 02:58 PM
laminate wood flooring - after installed reds_21 Flooring 6 12-04-2009 08:22 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
