Laminate Wood In Entryway - Flooring - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 06:50 PM   #1
Laminate wood in entryway
I have installed laminate wood flooring in the upstairs of our split level home and I am wondering which direction to lay it in the entryway at the bottom of the stairs, any ideas would help
aesop313 is offline   Reply With Quote
Old 11-25-2011, 08:22 PM   #2
dannyoung85's Avatar
The general rule of thumb on plank flooring is to run it perpendicular to the way your floor joists are running.
dannyoung85 is offline   Reply With Quote
Old 11-25-2011, 11:19 PM   #3
I always lay the planks with the length of the area. If your sub floor is 3/4 tongue and groove plywood the joist direction really doesn't matter.
plowboy is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Tile backsplash if have laminate with wood edge?? simiesue Remodeling 4 04-12-2011 01:15 PM
Installing laminate flooring over wood floor. onenonlydano Flooring 0 03-06-2010 10:26 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 03:20 PM
