-   -   Laminate vapor barier underlayment question (http://www.diychatroom.com/f5/laminate-vapor-barier-underlayment-question-18764/)
amdspitfire 03-20-2008 06:15 PM
The laminate has pad backing already so all I need is a plastic sheet underlayment. The 6mil sheeting in the hardwood isle is very expensive but comes with a nice strip of tape so you can overlap the layers.
Can I just get a big roll of some 6mil plastic sheeting? Like the black garbage bag material stuff or should I stick to the fancy stuff?
AtlanticWBConst. 03-20-2008 06:38 PM
You can use 6 mil Poly.
Tape the edges with Tyvek Tape (House wrap tape).
amdspitfire 03-20-2008 10:25 PM
So this kind of sheeting will be fine?
http://www.restockit.com/12-x-100-6-...source=froogle
AtlanticWBConst. 03-21-2008 05:04 AM
That's fine.
You could use that or even the "clear"...whichever is more "cost-effective".
amdspitfire 03-21-2008 10:48 AM
Originally Posted by AtlanticWBConst. (Post 109597)
That's fine.
Thanks a lot, just trying to make sure this stuff will work instead of spending a bunch of money on the fancy stuff in the flooring isle.
