Old 03-16-2010, 11:01 AM   #1
laminate transition edge
Coming over from carpentry, didn't realize there was a "flooring" area!
Yesterday we installed laminate flooring in a neighbor's house and had one hang up: the old floor was level with the entry door to the garage and there is no threshold . We didn't take up the old flooring so by adding laminate we have raised the floor 1/2". I see our options as 1) run laminate under the door to the edge of the step and cut the door down (its wood, not steel) or 2) use a bull-nose transition piece at the door. HO doesn't want to do the bull-nose because he thinks a 1/2" step up inside the door is going to look bad. I think cutting the door down is more odd. Thoughts? How is this typically done?
moneymgmt is offline   Reply With Quote
laminate transition at entry door moneymgmt Carpentry 4 03-16-2010 10:59 AM
Transition from edge of step oguevarra Flooring 6 12-16-2009 08:32 AM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 09:22 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 07:34 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 11:44 PM
