Laminate Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 12:52 AM   #1
laminate transition
I put down laminate in the family room. When I got to the door to the garage I unscrewed the heavy metal threshold intending to put it back down later. Turns out the laminate raises the edge too much and the door won't close. It also tilts slightly, so planing the door won't fix it. I tried to bend it a little but it's too thick. The only alternative I can think of is to grind 1/8" or so off the edge. Is there a better way?
davide210 is offline   Reply With Quote
Old 01-04-2010, 12:55 AM   #2
is the garage door metal?
sourek is offline   Reply With Quote
Old 01-04-2010, 07:31 AM   #3
Sounds like you need to trim the laminate back from the door. You're supposed to leave it floating, and not do things like screw transitions to it, which can prevent it from moving and cause the joints to open up.
To me, this is the biggest downside to laminate flooring. In order to leave the required clearances (as per the instructions), there are some details that don't seem to have good solutions.
pyper is offline   Reply With Quote
Old 01-04-2010, 12:14 PM   #4
I laid the laminate up to the door but not over the screw holes. I considered cutting it back even with the edge of the threshold, but that'll look bad because the threshold slopes.
The door is metal. But since the threshold tilts I don't think trimming the door is right anyway.
Old 01-04-2010, 12:31 PM   #5
can you use a lower profile threshold?
Old 01-04-2010, 12:48 PM   #6
That's the kind of thing I was talking about -- you're supposed to leave a 3/8" gap between the flooring and the threshold. You're right -- it wouldn't look good. But neither will the floor coming undone (or buckling).
Since the floor is down you need some kind of fix.
One solution might be to make a threshold from oak that can screw down using the existing holes and "float" over the flooring.
Old 01-04-2010, 01:35 PM   #7
I can do that. Is that acceptable with a fire door? (Not sure if it's considered to be one.)
Old 01-04-2010, 02:09 PM   #8
I don't know about fire doors. Someone recently said they have a plate on the jamb side if they are rated.
Old 01-04-2010, 04:05 PM   #9
No plate, so I guess it's a go. Thanks for your help!
Old 03-20-2011, 05:12 PM   #10
You could reset the door as well
IceT is offline   Reply With Quote
Tags
laminate , threshold
laminate flooring - transition suncowiam Flooring 4 09-11-2009 11:37 AM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 09:22 PM
Laminate to Carpet Transition Dallas Flooring 3 12-21-2008 07:32 PM
tile to laminate transition SML93 Flooring 5 03-22-2008 06:11 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 11:48 PM
