Laminate To Tile Transition... - Flooring - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 06:41 PM   #1
Rewards Points: 115
Laminate to tile transition...
hey all, need a fresh perspective here. So, I purchased a laminate to tile transition strip from one of the big box stores. It's the style that has a track about 0.5" long. Problem is my tile guy left me a bit shy of the 0.5" needed. So, I'm trying to figure out how to widen this gap so that I can screw in the track and place the strip. Any ideas? I need to go through 1/4" of laminate and 0.5" of subfloor to get myself the 0.5" needed.
Here is the strip: Laminate to tile transition...-img_20130319_152246_866.jpg
Here is the gap: Laminate to tile transition...-img_20130319_152203_054.jpg
I tried to shave some of the laminate away with a dremel cutting disk, but it didn't work that well because the diameter of the disk is too small...
Didymus21 is offline   Reply With Quote
Old 03-19-2013, 07:45 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
The laminate and tile both ended in the wrong place. The transition should go directly under the door so when it's closed, what is on the other side is not visible. You should call the tile guy and have him come back and fix it.
sam floor is offline   Reply With Quote
Old 03-19-2013, 07:50 PM   #3
Rewards Points: 12,824
You can sill make it work, just going to have to redo that last piece of laminite.
Old 03-19-2013, 11:54 PM   #4
Rewards Points: 115
We had a discussion about where it would end. The original HO had it end in the wrong spot. I was unable to find matching laminate floor so I told him to end it there and I'd just use the transition strip and call it good. Didn't expect it to be such a pain.
Old 03-20-2013, 08:43 AM   #5
Not 100% correct but I'd just use my ossilating saw and cut back the laminite, easyer then redoing the tile.
Old 03-20-2013, 10:57 AM   #6
Rewards Points: 115
Thanks. Figured I just didn't have the right tools for the job. Might have to go pick one of those up.
Old 03-20-2013, 02:17 PM   #7
Rewards Points: 14
It looks like from your picture that your tile and laminant are the same height and that you have a reducer transition strip. If they are the same height, are you sure you wouldn't rather use T-molding instead? Agree with previous poster to cut laminant with oscillating saw. You may want a few extra blades, as the aluminum oxide layer eats up blades pretty fast.
Indywar is offline   Reply With Quote
The Following User Says Thank You to Indywar For This Useful Post:
Didymus21 (03-20-2013)
Old 03-20-2013, 03:29 PM   #8
Rewards Points: 115
Good to know re: the blades. Could you recommend a specific blade? BTW, tile is about 1/8" higher than the laminate.
Old 03-20-2013, 04:08 PM   #9
Rewards Points: 14
I'm sure other folks can recommend their favorites, here are the ones I have used:
saw-http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
blades-http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 03-20-2013, 04:27 PM   #10
Rewards Points: 115
Can you resend the blade link? You sent the tool link twice. Thanks.
Old 03-20-2013, 04:29 PM   #11
Rewards Points: 14
Sorry.
Wall tile to baseboard transition? wraiththe Remodeling 11 01-10-2012 08:29 PM
Tile to Hardwood Transition politronics Flooring 7 11-29-2011 05:55 PM
Tile Height versus Laminate doedoe Flooring 2 07-30-2011 01:02 PM
Do I need waterproof barrier OVER tile in basement before laminate? Mary T Flooring 1 06-19-2011 11:51 AM
Curved tile to carpet transition toocheaptohire Flooring 5 04-16-2009 03:37 PM
