Laminate+stick on tiles+linoleum Good Idea??
I was doing a small"ish" job friday : Laminate floors from Simple Floors installed in a foyer that flows into the kitchen and breakfast.. the foyer previously had engineered floors glued-down to plywood. after removing that, i installed a 1/4" plywood to level the foyer with the other areas, which were 1/4" higher and had vinyl installed. At first i wanted to go over the vinyl with the laminate, but when removing the molding the vinyl came up around the edges. So i decided to rip it up. to my biiiiig surprise, the 1/4" existing plywood was all wet(probably condensation under the vinyl) and the entire area had mold forming in between the vinyl and ply. So now i've put the project on hold and am having a company do mold treatment.
the point of this? I want to retract the previous comment and strongly suggest rippin out the existing linoleum and stick-ons.... if you the find there's a diference in level, you can install a new layer on thin ply to make up for that....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 50% down, 50% after all your complaints....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. hardwood floors, To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
