Laminate Stairwell Troubles - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 04:43 PM   #1
Question
Laminate stairwell troubles
Hi there,
I am installing a half inch laminate flooring on a stairwell with a platform and 90 degree turn. I am using stair nose pieces and I need help figuring out what to do on the platform and the side of the stair that is visible. I will post pictures to help you understand.
Laminate stairwell troubles-dscf2941.jpg   Laminate stairwell troubles-dscf2947.jpg
DavidChase is offline   Reply With Quote
Old 04-28-2011, 05:55 PM   #2
woodman58's Avatar
On the side all you do is cut laminate and liquid nail it. make sure and cut the exact profile of the step so the stair nose will over lap the sides.
woodman58 is offline   Reply With Quote
Old 04-28-2011, 08:17 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
use the material you are using for your risers and miter it around that step just above the platform. Do the same for the step right above it. Have the nosing material run the full width of the platform that way it will cover the joint where the top riser of the lower section meets the riser of the upper section. Also run miter the nosing on that upper step and run it back to the drywall. The nosing will cover the next joint.
Millertyme is offline   Reply With Quote
Old 04-29-2011, 05:54 PM   #4
Smile
I think I got it done correctly ... i was working pretty hard yesterday and towards the end of the day I was having trouble thinking, once I got there today It came to me pretty fast... thanks guys
Old 04-30-2011, 05:20 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
Thats it. Just what I was thinking. Looks good. I would just run that landing nosing all the way to the stringer on the left. Keep it in line with the nosing above.
Tags
laminate hardwood , stairwell
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 12:43 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
