Laminate On Stairs - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 07:46 PM   #16
Rewards Points: 13,266
It should never be used on stairs, plain and simple.
Use Real wood treads instead.
There still laminated but in a different way.
There strips of real wood glued and pressed together. There done that way to reduce cupping.
Old 09-17-2013, 08:58 PM   #17
Thanks Joe! So no engineered wood on stairs? The instructions seem misleading. You'd think they would be more forward about advising against it. Thanks again.
chicosfsu is offline   Reply With Quote
Old 09-18-2013, 11:44 AM   #18
Stairguy
Millertyme's Avatar
Rewards Points: 508
Engineered wood is different than laminate. It's usually veneered plywood of some kind. Much more stable than laminate flooring i wouldn't worry much about expansion with that
Millertyme is offline   Reply With Quote
Laminate at base of stairs daisychain Flooring 0 11-29-2010 02:22 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 11:52 PM
HELP - laminate on stairs mf915 Flooring 6 07-11-2007 11:12 PM
