Laminate On Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 04:05 PM   #1
I'm installing laminate on stairs and have 2 questions ... 1) do I use the underlayment? and 2) should the risers sit on top of the treads? thanks in advance for the help
p.s. thanks for the input, but my question isn't whether or not I should put it in (I'm committed to this and i have the expansion issue handled) its about using underlayment and position of the risers/treads (please see above)
pblooper is offline   Reply With Quote
Old 09-10-2013, 04:10 PM   #2
Rewards Points: 13,960
If your talking about laminate flooring, not a great idea.
Way to many issues.
It needs to be able to expand and contract in all directions so there's no good way to finish off the ends.
The nosing they sell for doing stairs is nothing more then a paper thin layer of what looks like shelf paper and will wear through.
Old 09-10-2013, 04:17 PM   #3
Way to many issues.
Thanks for the input but I'm committed to this. the material I have is top of the line and doesn't appear paper thin whatsoever. Any thoughts on my original ?'s is appreciated.
Old 09-10-2013, 04:42 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Still not a good idea. The laminate will buckle and if it can't move it will split.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-10-2013, 07:00 PM   #5
Ha what do we know, we just do this stuff every day for a so called living, but there's always something new to learn.
Post a picture when your done and let us know how it works out.
Make sure to let how the slippery treads and the raised trip hazard nosings work out.
Old 09-10-2013, 07:10 PM   #6
will do Joe, but what about the underlayment
and riser/thread position?
Old 09-10-2013, 07:35 PM   #7
Framing Contractor
Rewards Points: 120
Generally, it would be riser first and then the tread. Glue is your friend here usually, but not so when dealing with the laminate.
sixeightten is offline   Reply With Quote
Old 09-10-2013, 08:40 PM   #8
Im a flooring installer and it would be risers than treads. U can choose to use basic laminate padding underlayment for help with sound. That's the only benefit of using it in this situation. You can glue or brad nail it. Leave 1/8 inch expansion on all 4 sides
Maroman95 is offline   Reply With Quote
Old 09-10-2013, 08:56 PM   #9
Bill Kearney
Rewards Points: 1,174
Doesn't matter how excellent a product might be if it's used for the wrong purpose. The downsides here are many, but the worst of which is someone getting seriously hurt.
wkearney99 is offline   Reply With Quote
Old 09-10-2013, 08:59 PM   #10
I've seen or heard of a laminate that can be glued or nailed down.
Engineered flooring yes, laminate no.
rusty baker (09-10-2013)
Old 09-10-2013, 09:46 PM   #11
Rewards Points: 142
Laminate is never supposed to be glued or nailed.
Old 09-10-2013, 10:03 PM   #12
Its safe in this case. The last thing u want is a "floating" floor on a stair case. I.have done this many times without issues.
Old 09-10-2013, 10:08 PM   #13
Rewards Points: 142
So you have installed it wrong many times and been lucky. What if this DIYer isn't lucky and someone gets hurt? The laminate makers say their products are not to be glued or nailed.
Old 09-15-2013, 07:29 PM   #14
Stairguy
Millertyme's Avatar
Rewards Points: 508
Most, or perhaps all, laminate flooring has an mdf core which needs to be able to expand or contract. Gluing down will perhaps void any warranty on the product. Although i dont like this product on stairs and do not reccommend it, it does get used. Why redo the stairs at all if your just going to use an inferior product. It's like putting lipstick on a pig. Oh, btw, risers always go first and use substrate reccommend on the box of laminate flooring.
Millertyme is offline   Reply With Quote
Old 09-17-2013, 06:38 PM   #15
This is an interesting issue. I am laying down Bruce Lock&Fold engineered wood on my stairs but I haven't been able to predict how it will act if it needs expansion on all sides (similar to my main floor), especially the front side that abuts to the stair nose. I thought to glue the planks down and keep the plank sides fairly flush to the sides of the stair molding. Should I rethink my approach?
chicosfsu is offline   Reply With Quote
Laminate at base of stairs daisychain Flooring 0 11-29-2010 01:22 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 10:52 PM
HELP - laminate on stairs mf915 Flooring 6 07-11-2007 10:12 PM
