Laminate On Side Of Steps And Direction - Flooring - DIY Chatroom Home Improvement Forum
Old 02-13-2008, 12:56 PM   #1
Laminate on side of steps and direction
I did laminate flooring in my living room. In the corner there is like a 1 step(for design in the corner I guess it was made for) that I would like to add laminate to it but unsure how I should do it. For the sides of the step I need to glue the laminate but what kind of glue should I use, just any elmers wood glue? In total theres 2 steps each one going a different direction. Should I just apply the laminate in the same direction as I did the floor? If so on the front step I would have a bunch of 12 strips of laminate on the front of the step, to the right step I would have maybe 3 long strips going the length of the step. I hope you know what I mean here. I could get some pics if that would help.
Thanks in advance!
83trekker is offline   Reply With Quote
Old 02-19-2008, 12:50 PM   #2
Anybody?
Old 02-19-2008, 02:18 PM   #3
electrical contractor
Rewards Points: 150
Laminate is meant to float, gluing it down would restrict that, I would not do it.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-19-2008, 02:26 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It is laminate "flooring" - Need we say more?
- Build Well -
Old 02-20-2008, 03:42 PM   #5
IM sure somebody in here hgas used laminate for the back of there stairs, what else would you use?
