Laminate Should Be Floating?? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 01:54 PM   #1
Laminate should be floating??
I have read here that laminate should be floating and should be able to move, so if you use it in a kitchen application it's some what pinned down by the frig, a table and chairs maybe some other cabinets.
How does it move?
Joe Tilghman is offline   Reply With Quote
Old 01-25-2012, 02:07 PM   #2
Remodeling Contractor
The movement is by expansion and contraction. These weighted objects will not stop this. No space along all wall edges will cause it to bind. Leave the required space and you will be fine. cabinets are fixed and the laminate should terminate before the kickspace, not going under the cabinet bases.
Old 01-25-2012, 06:02 PM   #3
Thanks for the reply.
Old 01-25-2012, 06:11 PM   #4
Rewards Points: 14,014
I try to avoid using laminet In a kitchen or bathroom.
Needs to move and most will be distroyed if there's a water leak.
It also looks to plastic for me.
But ha it's your house.
floating laminate across 2 concrete floors landed Flooring 6 07-22-2011 08:34 AM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
Laminate Floating kitchen floor/cabinet install kearnsj Remodeling 6 12-17-2007 04:04 PM
